Current set up is a 2012 Silverado 1500 with spring over(Deaver U182) with 2.5x16 triple bypass. After building a new rear end and looking to get a 2 piece drive shaft made, I realized my pinion angle is way off, which is making me wanna look into a better option than to cut off my perches and re-do it the same way. I currently am running CWF shackles, my question is… could I use my same shackles if I went with the Deaver C85s and went spring under… could I use the same shocks also? They’re currently set up and mounted on top of the Deaver. Any Silverado guys with spring under please chime in! Thanks for reading
