JRI Gen1 Raptor
I really want to tear this thing down and get it dirt ready or ready enough to actually use real soon. The only problem is two is one and one is none, need to fix our 2006 Ram so Mama can drive that while the Raptor is apart, of course the Subaru is always an option...
Only been sitting for a year because I tore it apart to fix its first oil leak @ 280k
OK, back to the Raptor. I have a light hum, off throttle and light on throttle. It was re-geared like 4 or 5 years ago, so there could be a bearing issue showing up now, I hope not. I decided to check the rear diff fluid level, she was full. Then I was going to jack it up and pull the driveshaft to spin the pinion yoke by hand and when I was jacking it up I noticed the right rear tire scrubbed a little, hmmm....right rear wheel bearing has a bit of play in it, I guess I'm buying new rear wheel bearings to put in my stocking this Christmas.
Hopefully I will be re working the front end in the next couple of weeks. One item on the list for the re work is new tires. We bought this truck with the Milestars that are currently on it and they are wasted. I typically buy BFG's. I will likely buy BFG's for the Raptor, but I am open to opinions on other tires.
