Turboyota
- Apr 1, 2022
BrobroBrent got a good deal on some Sway-A-Way Racerunner 8" shocks that came with extended ends, extra shims, and swayaway Baja Blood shock oil.
Time to cut shit apart!
Plasma cut out the passenger side. Had to sawzall through the coil bucket lip areas.
This is a scenario where the plasma cutter is like 10-20X faster than grinding wheels. It would have taken 4 hours and $30 worth of 4.5" cutoff wheels and sawzall blades to cut that shit out the hard way. With the plasma cutter, it took less than 15 minutes to hack that section of frame out.
Lesson: Buy a $240 Colossal Tech CUT50D Chinee Prasma cuttel from eBay. Trouble free for years, and consumables are dirt cheap.
Kyle grinding as I nurse the huge burn on my forehead that was the result of dripping melted plastic from inside the coil bucket somewhere...
Plated in the frame with rusty 1/8" HR plate
Burned it in
Cover plate for upper coil bucket area. This plate welded to the insides of the upper A-arm tabs also. Said tabs had LOTS of cracks that were ground out and re-welded.
Same deal on driver's side:
Brent bolted up the arms for another fit check, and at that point we abandoned the project...
....And started drinking!
Burned it in
