Class 2000 ranger
Put 250 or so miles on the truck the last 2 weeks. Only casualties was a blow shock seal and power steering pump is about to leave the chat. Truck got fast with some bypass adjustments but need to send the leafs out to add a few leafs as the F31s are a tad to soft.
Got tired of everything not matching. Figured a garage built truck needed a driveway rattle can paint job. I'll finish the front clip tomorrow
It's all painted. Turned out pretty ok. Now on to trying to get it dialed in and buy everything else I need in an attempt to make the first MORE race of the year.
Soft would be better IMOP. Maybe you just need a larger shock in the rear with more valving? You don't want it too pogo sticky in the back.
Too soft generally causes trucks to buck. You run out of travel, hit the bump stop hard and it’s all out of control from there.
The 7s I raced all season I can confidently says has never kicked/bucked but it’s stiff enough it has only touched the bump stops maybe 5 times in a full year of racing. We launched it as hard as we possibly could at glen Helen and didn’t touch rear bump stops.
I'm gana revalve them Friday and go out this weekend again. I'd also like to get the pack re arched to get alittle more bump travel too. I'm at 8.5-9" I'd like to be closer to 10.5"
Luckily the truck doesn't want to buck right now but I get into the bump stops pretty often
Spring Rate shouldn't exactly manage the compression side of shock tuning unless I'm incorrect.
Went out to do alittle more shock tuning after changing some valving. Truck feels more planted and its faster through bigger bumps. Still getting used to how the truck reacts and drive but it's fun and getting faster.
Traded my F31s for a set of G50s. The extra swing rate and arch is a huge improvement. Went from 8" to 11" of up travel. Need to take the truck out testing again to see if it needs a revalve. Also pulling the truck apart in te
He snow sucked
The easiest thing would be moving your spares back a little further IMOP vs adding stuff that doesn't add to the cause or whatever.
I'm no Math guy but I bet 10" further back of 200+ pounds does a lot at that leverage.
Very true, if we treat the axle as the fulcrum the 200lbs of tires on top of that would exert the same 200lbs or ~90Kg of mass. The further they’re moved back the longer their lever arm becomes and the 90Kg of mass becomes hundreds of pounds of force acting on the rear of the truck due to the mechanical advantage. So if the tires are placed 4x the distance from the fulcrum as the load, the lever gives you around a 4x advantage aka 200lb tires act as 800lb. In short Wally is right and placing the tires further back is smarter than me using stupid thick steel LOL.
Sorry for using commie units but my engineer blurb is done and I will now revert to my weekend status of dumbass extraordinaire 🤡
Finally got the truck out to a race. Was having a blast and it was working pretty good. Right up until I smoked a big rock with the driver side beam halfway through the first lap. Pulled into the pits and realized we had 2" of up travel before the beam was smashing into the passenger side mount and engine cross member. So now I think its equal length beam time.
Time for some 2 tube or fully plated radius arms. That bent right where the stress riser was created by the front boxed portion ending
