MAY 13 2025
I was able to get some time in the garage after work, i wanted to get the front end pulled apart to start the prep. I havent done shit with it since the install 2 years ago as far as maintenance, honestly there is 3 desert trips and about 6k miles on it since the install but i figured i might as well prep to see how shit is holding up.
PULLED IN READY TO GO
Visual inspection was good other than the upper control arm to spindle bolt had a shit ton of surface rust that will be getting changed out to a grade 8 unit now to tear it down.
I got the driver side all stripped off besides the lower thinking i would keep them on to get a ball park length for making my tie rods with heims. Come to find out the lowers are not going to help me at all, i will need to make tie rods when its all going back together.
next on the list will be to pull the lowers and steering rack, then start with the upgrades. I have solo motorsports cam tabs that i have pictured earlier in the thread i need to install those, i have plate from SHP fab out of corona to plate the crossmember where the rack bolts onto to hopefully keep the rack from ripping the mounting material.
I did find when pulling my upper control arm that the bolt on the driver side is bent, do any of you Toyota guys know if i can buy a grade 8 bolt
for up there. Im also looking to run the total chaos lower uniball conversion, just not sure its worth the 1000$!!  Other than that everything looks as it should especially with only 6k miles.
