4XForOffroad
UCA bolt is a M14 so 9/16 grade 8 the same length would work. Or this approach replaces it with shorter bolts.I was able to get some time in the garage after work, i I did find when pulling my upper control arm that the bolt on the driver side is bent, do any of you Toyota guys know if i can buy a grade 8 bolt
for up there.
October 2021
Starting fitting the double shear plates for the upper arms. I got the total chaos ones and they fit good! I used the All-Pro Off-road ones on the Tundra rebuild and they fit like shit!!
Also changed to upper arms to separate 9/16” bolts instead of that uber long factory 14mm bolt.
Did some staring at the engine bay and trying to visualize an engine cage. There is zero room above the intake when the hood is closed. I’m going to have to work around the intake for sure.
If it bent though it might have been taking too much load and front is not bumping out before it’s putting a lot of load on the shock tower / uca bolt.
