92singlecab
- Sep 10, 2024
I have a 92 ranger with I beam suspension. I want to do a mid travel/long travel build relatively on a budget. I want to build this truck to go through the desert at speed and handle well through whoops.
What are your guys recommendations for I beams, should I get my stock ones bents and weld a coilover mount, or should I get custom ones made? If so what places do you all recommend I should buy beams from, or send my stock ones? Would the stock width beams be good to run with the coil over or should I try to get some wider I beams? If so what beams do you all recommend?
For the coil over I was debating between a fox 2.5 x 12 or a sway a way 2.5 x 12 or 2.5 x14 both remote reservoirs. What do you guys think will work better or the same?
Any other ideas or advice is appreciated thank you
