Advice on I beam coil over setup
Another quick update!
I’ve been doing all the little nickel and dime things that need to happen before the front end goes together.
I got 2 new heims for the steering linkage and took the old one out. Welded the shock mount as shown previously. Got the misalignments for the radius arm bracket, replaced the axle pivot bushings and now am waiting on brake lines and getting some coilovers made.
I know I said I would do coil overs later but if I already have to make a shock hoop, why not go all the way? 😂
Thank you to everyone who’s followed this thread this far and offered any advice! It’s truly the reason I’ve been able to get this far.
I’m hoping to be able to throw it all together by the end of the month!
Another update on the ranger!
I said I hoped it would be together by the end of the month and it is (sort of) haha!
Over the weekend me and a buddy ripped it apart and installed those marketplace beams and radius arms. And I put a stock style coil spring with a tie down strap holding it in just so it’s drivable.
The only things left to do for the front end now are finish mounting the radius arm brackets, (2/4 bolts are in on each side) and make a trans crossmember. After that I’m dropping it off at a friends shop where they’ll make the shock hoops for those coilovers.
Hopefully I can get it out in the desert before the seasons over!
I second a set of Geoffs Beams! Been running his equal length beams and links for many years now with zero issues. Best bang for your buck! May sting at first, However in the long run you will save yourself a ton of time and money if you start with some decent suspension rather than trying to "Make due"
I have a 91 ranger. The beam kit is like $3500 which I can afford but what else will I need to buy to have it mounted on my truck and working?
I haven’t looked at the kit in a while but I believe you need Dana 44 hubs and spindles, the crossover steering, coilovers, brake lines, and will have to make custom shock mounts on the truck to mount your shocks. That’s just off the top of my head though you may need more. They’re a pretty easy install but they do require custom welding work.
decided to go similar to you. Messaging a guy on marketplace about some auto fab beams, if I can't get those Im going to pick a part and pulling some forged beams off an 86 ranger (ill have them cut and extended). Trying to find radius arms right now. Then I'm gonna buy the solo motorsports shock hoops and some used coilovers. How have the extended beams held up? Any issues with stock steering?
That setup sounds like it will it work well! The only thing I can say if is you’re going to have custom beams made try to have the radius arms made at the same time to match the beam geometry. Everything’s been working good! I got my truck back a few days ago and been ripping it around, with stock steering the biggest thing is alignment. How the front wheels are aligned make a big difference in handling
However. My truck cycles 18” of travel up front with stock steering and after I had it aligned it handles great
Hey guy....any updates?
92singlecab
There’s quite a few haha! Sorry I kinda let this form die out but here’s an update on how the truck sits now:
Front end is done with those marketplace beams and radius arms, 2.5x14” coil overs that have been sprung and valved for that truck
It cycles 18” of travel but is strapped at 16”
Had a full engine cage built and I built a cold air intake for it.
The rear end got a new used pair of deaver f31 leaf springs with some bilstein 5100’s (soon to be raptor internal bypasses) and a stock flipped shackle.
Just been keeping the truck running and up to date on maintenance but man is it a ripper! For ~8k build I don’t think it gets better than this, and there’s still more to be unlocked with the truck just need the bigger parts.
The first 3 are how she sits now, the others are some of my favorites from driving it.
It’s currently listed for sale for 7k on marketplace, or trade for an explorer of equal value/mileage
https://www.facebook.com/share/1YyhR6e3Sv/?mibextid=wwXIfr
If link doesn’t work look up 92 ranger it should come up
But all in all it’s been a great truck and a fun build and I learned a lot from it! I hope anyone else who read this forum learned as much as I did and thanks to everyone who responded to it and helped make my vision a reality!!!
