98 F150 - Frankenstein
After getting stuck in johnson valley for 3hrs and putting a dent on my trans oil pan, i started planning to get some skid plates made for them (not there yet) IMG_5684.webpIMG_5683.webp
Bought another set of tires, barely used. Toyo MT 37x13.50x17” load range E. Personally love these tires for offroad but paired with my walkers, they're 135lbs each, lot of weight to push around with a V6.4A6D901B-9C83-4BAC-8314-695CF4AD7639.webp
Sometime after that purchase, i tore an oil seal in one of my bypasses. Took it apart at work, fresh oil, few new seals, polished shaft, and it was back on. IMG_8579.webpIMG_8580.webpIMG_8593.webpIMG_8596.webp
Scored free paddle tires for glamis as well but never got around to mounting them. Not even sure if i can run them, as they came off a sandrail and might not hold the weight of my truck. Plus would need to take some scoops out to save my trans lol. IMG_9180.webp
The lights i had on the bumper were also a free score as stated above, only 3 of the 4 worked then eventually only 2 and it wasn't cutting it for me anymore. I bought 2 pairs of the pro 6’s from KC with amber covers, wide 40 beam. It’s honestly been a great upgrade. When theres too much dust, i can switch off the roof lights and just use the bumper lights and works just as good. IMG_9186.webpIMG_9221.webp597CD3EA-D237-47B1-A5C1-8C8A6571F332.webpIMG_9233.webp
Blew the U joints out of my driveshaft some time in april, replaced them Dirt Skum’s help and they DNF’d about 6 months later. Then took it to driveshaft pro and they rebalanced it and replaced both joints. IMG_9187.webp
Lastly, some time in November, the nut that holds my idler arm on, backed off and lost on the road somewhere. I only caught it because the wheel was a little more loose than normal lol. I still drove it home like this too. I tightened 1 of the 2 idler arm bolts (the other was gone gone) and drove it back. A friend later welded it to the frame per my request. IMG_9243.webp
Prerunning the MORE championship in December, i broke the last lateral mount holding my driver side fender on and only 2 on the top. Decided the best bet was to remove it completely. Im not going to fix it as the 1 piece is going on soon (fingers crossed before KOH) IMG_9591.webpIMG_9611.webp
Scored the free race air and installed it in the rain on new years eve. Bought new hoses and a bracket to hold it in. Musgrave’s said it was 15 years old lol it is loud as fuck but it was free. Im basically at that point of not hitting dirt without my helmet and hans device. Just never know when something bad is gonna happen. So the race air has become a necessity too.IMG_9623.webpIMG_9914.webpIMG_9931.webp
Last trip out January 2nd, did 45 miles before heading home on a day run.
Where im at right now, besides the hood fiasco with getting it installed over the course of 4 years lol. Im due for rear brake rotors and the fronts could be too. Im going to buy the dana 44 rotor hat adapters from wilwood and get them redrilled to my wheel pattern. Im tired of having to take my hubs off every time i want to change my rotors and having to use a press for my studs. Wilwood rotors, all 4 corners. Rebuild kits for all 5 calipers, 1 went bad due to negligence. New front wheel bearings and 2 sets of pads.
Aluminum dash and center console after the hood and brakes, also need an alignment bad. Hangers need attention and might just wire wheel and grease tf out of them, see if it goes a little longer.
Would like to find a stock LS1 and get parts going for a future engine swap. Back half also around the same time.
