KaiserJ
- Mar 26, 2023
quite a few weeks behind on updating this, but got the new top end all sorted out. Ended up doing new heads and re gasketing everything, changed out the MAF, T-stat, new lifters and new injectors. Rocker arms and push rods looked brand new still from whatever previous rebuild this thing got before I bought it. Also replaced a bunch of vacuum lines & purrs like a kitten again! It still needs a fan clutch as the temp seems to fluctuate a bit and the ‘91 I previously owned has the same issue, but easy to fix. Next up is to install the Cookcraft rear shock mount that utilizes Gen 1 Raptor rear take-offs, or 12" King bypasses up to a 3.0 with a different lower shock mount. This kit pulls 14” of travel from droop to bump with Deavers and maintains everything under the cab! Its the perfect solution for a rear shock upgrade without sacrificing cargo or sleep space.
Shock mount on Ryan’s Explorer:
