92 Toyota Pickup
YotaTyler418
1000 Oaks
92 Toyota pick up 2wd
Plan:
-build bed cage to fit the 18in triple tube bypasses that came with the truck
-2 spare tires in the back
-some sort of roll bar or roll cage
Took the leaf pack apart
Whoever originally installed the bump stops decided it was a good idea to have it bump off of the u bolt lol.
Cardboard template for bump plate
Thanks to Mike at fablab for cutting the plates out, First time welding and I'm stoked with the results
Bump plates are installed and welded to the axle
Squishy brakes is air in the system, firm yet falling is leaky cylinders, leaky fittings lead to no brakes and good times.
This looks like a fun little truck, can't wait to see it in action. I have a wider rear axle that will mostly drop in if your interested.
I highly recommend a Motive power bleeder for doing the brakes. For Toyota you will have to use the Motive 1101 cap or the complete 0101 which include the power bleeder and cap needed. I used it for my Tundra and didn't spill a drop and cured my squishy brake problem. For what it's worth, I can bleed the brakes on my car with 8 bleeders total in less time than it takes me to get the car on jack stands and remove the wheels.
First trip out was definitely a success!
The rear window decided to shatter from a rock getting thrown in the rear window
Few pictures of the truck over the weekend
The truck worked great and I'm beyond stoked with how it came out!
Next:
-The rear end is way too stiff and shocks need to be revalved and rebuilt.
-Need a new rear window, thinking lexan
-Bedsides need to be mounted and tail lights wired up/mounted
-Front lightbar
View attachment 4504View attachment 4505
Next:
-Front lightbar
Hell yes!
This thing is rad ! I have a rear window I'll sell for cheap .
Bring this bad boy out to Pedals and Pints on Saturday in TO
Elliott
Keep a glass window back there and figure out some paneling to stop rocks from doing that. Leave scratches super bad.
