Turboyota
- Apr 1, 2022
1. Fuck youOptical illusion..
You old bitch! Lol
2. If it’s perspective, and it’s an illusion, Fosters tall cans on me(whenever you have a dezert truck again, of course…)
You old bitch! Lol
You better hope they still make Fosters tall cans by then.. they may be vintage(whenever you have a dezert truck again, of course…)
Finally some full size pics of this bish. Looks great.
Barely enough room to get back window out?
And did I read that right? 8" narrower in rear?
Am I seeing this correctly? Are the left and right link pockets different?
Thank you for the support dude! And thank you for following along, its been a journey so far to say the least hahaSuper bitchen Christian and Jake! You guys are killing it! I also watch your YouTube videos.
THAT ODI GRIPPPPPP dudessssss....This thing is such a rad build.
That spare hold down is awesome, but how does it do with a flat? It looks like there is a small range of where it will apply pressure while being locked. That's something that has kept me away from doing a solid hold down like that instead of a Y strap
I've been wanting to do this on the dual case shifters in my shit box... ODI will even do Custom grip locks... you could do Wings World or Vital DesignsGotta throw some homage to the bmx backgroundODI lock on for all the things. I also did one on a hand brake I made a while back too View attachment 12137
It locks in the center of the wheel with an ORI poly mount that’s adjustable. So this setup can be ran with any size tire, any wheel offset and be adjusted down to hold a flat tire if needed with just loosening up a nut real quick and threading it up or down. Most of these style hold downs that ive seen have a pedestal under the center of the wheel that has some sort of hub centric ring on it that the wheel sits on, but depending on how the hold down/latch is done, you are limited to whatever wheel/tire combination you originally set it up with. On the one I did, there is no adjustment in the latch, all the tension is set through this center peice to hold the wheel/tire down so you can run whatever you want
I've been wanting to do this on the dual case shifters in my shit box... ODI will even do Custom grip locks... you could do Wings World or Vital Designs![]()
i am freaking blow away by the quality on this build. Thanks for making the rest of us look like kids.
