Chancegoodman
Looking at this makes me just want to chop my truck in half and just start building it even though I’d have no clue what I’m doing
I've been wanting to do this on the dual case shifters in my shit box... ODI will even do Custom grip locks... you could do Wings World or Vital Designs
That outside miter weld is on point! Those are tricky for me to not make them have a tall profile.
As for the weld washers, they look great, but if you put them on the inside of the plates it spreads them a bit farther apart so the caps aren't as prone to being gouged.
If you put the plate/bulkead/divider in the miter junctions, it really helps with the space for weldment.
1. its more of a "how" or "way that you do this or that". as i type this, im looking at the pics of when you did the swaybar and setting it up and stuff.
HOW do you know where to set everything? if its me what i used to do is just tack shit somewhere, cycle it, re-rack/move it, cycle again, and over and over until i got my desired numbers in whatever it was that i was working on.
BUT that ended with fuckload of tack marks ground off everywhere/looking like shit.
THIS build, at least the pictures you posted, looks like every fucking tube was already planned out in a SW drawing, then laser cut and notched, then given to you like a puzzle. put this piece here, this there, notches are perfect, then just set your welder correctly and you'll have Camburg shop style welds all over your truck.
is that not how this build has gone, and can you explain?
thats at least what it looks like to me, with a lot of these builds nowadays.
maybe more in a summarized rAtard version for me?
2. HOW, specifically did you add this tube piece for the miter?
it's not just a 1" piece of tube butted up to the stub coming out of the cab, right?
just my thinking, if i had access to a mill or lathe.... id buy a 2" x .250 peace, then put it in the lathe and cut the OD off of like 2 or 3" to sleeve INTO thee main A-pillar peice that stubs out of the cab, then the miter would meet THAT piece
3. more for the welds part.
HOW do you, or everyone who does this/ends up with this style of prepared tube and NOT just a fucking flapdisc grinder to the end of a tube, clean all your tube ends?
maybe not in this exact pic i'll attach but it always looks like people just put the ends of thier tubees in a machine and it grinds/mills off the exact perfect amount of millscale off the tube, which also prepars you for a perfect weld
4. WHY do you put this bigger DIA sleeve on the endsof some of the fender mounts? i get why you and others do it on spots that see a lot of stress, but i always see it done on the specific fender mount type tubes????
5. what do you use/how do you clean all the frame rails and stuff? im used to just taking a grinder and w/e mood im in, either going fucking hard dig grinding the frame paint away or if im more relaxed/just go laid style just lightly (but still with a 4.5" flapdisc) grinding the paint and shit away.............
(ANYONE ELSE READING THIS, THIS IS ALL REFERENCING TO WHEN I USED TO FABRICATE BEFORE YOGA TOOK OVER MY LIFE AND I TURNED GAY AS FUCK)
6. the more i read, now im on the front end you built, it seems like you must have drawn everything in SW and laid all the tubes out perfect..........
Am I seeing this correctly? Are the left and right link pockets different?
Alright this is a big one so I'll try my best to answer everything thoroughly for you haha
1. Everything has just been thought out as much as i possibly can, trying to stay 10 steps ahead and not shoot myself in the foot for something coming after, and then the rest of it is just going by order of operation and importance. So for example on the rear, first things that come into play are getting rear end geometry setup and the truck bumped out where you want it, then you get the main cage tubes in. Figuring out width for the main tubes came down to what the fuel cell width was on this truck. So there is that parameter set, after the main cage structure was there, the next most important thing was shock mounts. After those were in, the bumpstops get mounted. The original plan for spare tire mounts was having a spare on each side of the fuel cell standing up, so I knew the sway bar couldn't come from behind the axle. The rear end width isn't wide enough to have a sway bar pass between the tires and the bumpstop cans, so the sway bar had to be packaged between the rear of the bypass and the bumpstops. Its all just order of operations, working from the most important things down to the less important items and making them fit where they are needed. Now that im getting into the more detail oriented stuff like exhaust routing, i need to mentally prerun where plumbing and wiring is going to go so I dont end up with things to close to each other down the road.
I spend a good amount of time just looking at this thing honestly. Thinking about future steps and where things are going to ran, be mounted, how to make the best use of space, have multiple things work together instead of all be mounted separately, how to make things look different, etc. Its not easy honestly. I don't have a crazy amount of experience building these trucks but I take what I've learned on other vehicles and put all of that knowledge into each truck I do to make them better. Whether that's geometry/performance wise, how things get mounted, layout, etc.
2. No, so from the start I didnt realize it until later but I fucked up on the length I left on the main A pillar tubes coming out of the back of the cab. Since I've never done an external B pillar before I didn't know how much length to leave, so when I started on the B pillar I realized really quick it wasn't enough space to be able to cut the angle into the main tube coming out of the cab. Once the B pillar was in for good, I made that little 1" adapter chinga to come out further away from the B pillar to have the miter come down from. All that stuff is 2" .120 tubing, I sleeved from the main tube coming out of the cab into that adapter with 1.75" .120 and then did rosette welds to tie it all together. That was a boner move on my part to not catch that from the start but I just didn't know better haha. Once the light rack is built on top of the main tubes behind the cab I don't think you'll ever even realize it haha. And the shock mount comes up into that entire area too and is welding all those pieces together really good so it will never be a real issue of any sort but its still something that bugs me
3. I use a palm sander with 60 grit sandpaper on all the tube ends or anywhere a tube is going to land for prep, as well as i add a good size champfer to all the tube ends with a flap disk to get a nice joint to lay a bead into! Bigger shops that have bigger equipment chuck the straight tubes up in a lathe and use scotchbrite pads or sandpaper to get the super gnarly crispy looking prep lines in the tubes and then on tubes that have bends in them they use a 360* tubing sander like a 525 industries die grinder setup. I just use what I can currently, as long as the metal is shiny where youre welding youre good. The crispy lines are only for the instagram photos anyways, all this shit gets painted anyways. Or rusted from sitting so long if we are talking about DR dudes
4. I have gotten into the habit of running bigger diameter on the chassis side for bedside mounts because its a cheat. I fit the 1.25" tube first and then just slide the 1" into it and i can pull the 1" tube in and out of the 1.25" tube to where i need it and then tack it in place instead of trying to notch and fit both sides of the 1" tube absolutely perfectly on both sides. Mounting glass is a motherfucker and is time consuming to make sure everything visually sites right and looks square, etc. So any cheat code I can figure out to make my life easier to square things up and be able to have some adjustment in I try and do haha. It really just allows me to adjust the bedside in and out on the top and bottom side until its sitting exactly how i want it. I will typically set width at the bottom and throw a tack on it, and then come up to the top and slide the tube in and out to site where the tail light looks perfectly vertical and not all cockeyed and then tack the top and move on to the other side. If I was trying to fit the 1" tube perfectly without the 1.25" tubes in there, I would have so much time spent going back and forth with the smallest adjustments to get everything to sit just right
5. Generally, to get a factory frame rail clean I will throw a wire wheel on a corded 4.5" angle grinder and just get after it. Its not the most fun or clean thing to do but it cleans the frame rails up really good without leaving any grooves or divots. On this truck, I did the frame plating previously when I did the old front end, so what you are seeing in that photo you added is 1/8" plate work that was all painted in steel it that i palm sanded back down to nice shiny raw steel again haha
6. Everything on this truck tube wise is all hand notched and fit with an angle grinder and there was no computer drawing of any of it. All the layout tube wise has just came out of my head. The beam kit my brother drew in the computer as well as the trailing arms, I drew the pivot boxes up as well as shock mounts. All the plate work items are drawn in the computer as much as I can to cut down on time spend physically cutting it out. Having the plasma table makes things so accurate and repeatable that it doesnt make sense to cut that stuff out by hand anymore. There is small stuff here and there where I do still get down on the bandsaw and hand cut things out, but if its something on the bigger side and especially things that i need multiples of, it gets drawn real quick and ill cut it out
