Thomas built motorsports 07 Ranger
I wonder if that would help me some with mine.... (i seem to lose a ton of pedal getting pressure to build because of the inline hoon handle to the rear)
I got the sway bar mounted, toying around the idea of bending the arms a few degrees to get the linkage more squared up with the trailing arms since they are so long.
Also started framing in the back window, idea is to only make one cut on the bottom of factory ranger glass and reseal so If I need to make a replacement it’s easy.
Rear shock pockets started aswell
are you finding glass that glues in? Like from std cab? All the extended cab glass I have seen is bolt in on the bottom... at least on 93-97
