Setting Ride Height - Dual Rate Coilover
4XForOffroad
LA
I recently had my coilovers rebuilt by @DialedShockPrep a couple months ago and I am putting the truck on its own weight for the first time with it being a completed running driving vehicle. They’re 10” coilovers and I have 500 over 600 lb springs. The truck isn’t caged - it’s a dual purpose truck I’d like to drive to the desert, explore, and get back home with. After reading his 50% up/down travel for non-race trucks, I know I need to shoot for 5” of up and down travel on the shock shaft.
What I’m not sure about is preload on main vs. tender spring and reaching that ride height. I know he says something like 1-1.5” of preload on a spring is “good” (I remember screen shotting something like that but I can’t find it on my phone to fact check myself). But how do I pick the ratio of preload between coils to achieve the proper ride height? FWIW it’s a 4x4 A arm truck and it’s got 6” of up travel out of 16”total in the rear so I am addressing that with an HD leaf pack I have waiting around for it.
I’m ok with a smidge less than 50% up travel as I don’t mind a bit lower rode height overall but if that’s a bad idea, I don’t mind going with the 50% up.
So do you have a cross over nut on the coil over or just dual spring in a stack with no cross over?
If you dont have a cross over a 500 and 600 spring stacked is really a spring rate of about 275lbs/in.
Got a picture of your setup?
On main and tender setups, you’ll set ride height with the crossover rings, and then droop the truck out and add 1” preload to the main preload collar. You can add more preload with the main collar, you just want to ensure that it won’t coil bind aka the slider stop rings lock out the slider before the upper coil binds up.
50-55% shaft at ride height is ideal for Prerunner play trucks, race applications i aim for 55-60% showing at ride height. This is also in reference to the bypass shafts since they are the shocks that are position sensitive, not just speed sensitive.
I have set up a ranger with 5” of shaft showing on the front of a beam truck, and it worked quite well, but would have been much better with more shaft showing at ride height.
It’s all a loose rule of thumb with these equations and there is definitely more to it than just sticking to those numbers but it will get you in the ballpark of having a good working truck for sure.
My buddy set up the coilovers to where they were set in the picture. It’s sitting tall without an engine at the time. My bad I should have said there was a cross over nut.
Is there a good tool you use for tightening the cross over nut? I think we used a thin pry bar or a big screwdriver and a mallet last time and it worked ok, but if there’s something good I’d like to try that as well.
Do I droop out the truck to spin the cross over nut while making adjustments for ride height?
You installed those yellow foam bump stops too but I assume the 5” is still measured directly from the rod end to the shock body?
I’m sure I’ll need to make a few adjustments / trips around the neighborhood getting ride height and alignment working out right. Pretty much everything on this truck has been put together all at once for the first time in 5+ years so it’ll be slow moving progress once I get it smogged and venture out little by little. Thank you for all that info. All the videos I found on YouTube were about selecting springs for dual coil setups instead of setting them for ride height although they were pretty informative other than missing that one thing.
