I did mine slightly different than yours I think. I kept it flat on the back side edge of the beam and then bent it inwards on the last couple inches. Yours looks straight the whole way and somewhat diagonal to the back side edgeMy back plate is welded in the exact same spot and my u joint has no interference weird.
There isn’t any room to do any sort of bracing on the left side of the crossmember with the 3rd and driveshaft installed. That right hand beam pivot is fully boxed and triangulated though. Still I am doing pretty much exactly that on the right side which will eliminate any rearward flex. The crossmember itself is super stout, so even only having bracing on one side will reinforce the whole thing. Already have the mounts figured out but just haven’t built an arm. The rear mount is the old upper control arm mount from the 4 linkLooks awesome. The Right hand beam pivot looks like it would want to bend up/back to the motor. Are you worried about this and gonna ad a tube to keep it from moving?
Thanks dude! Ttb swap everythingThis is so freaking cool. Nice job dude!
Patience young one
Just had to ditch that dumb solid axle lol! Thanks dude!I was always luke warm on XJs, this one is sick!
TTB rearPatience young one
Just unloaded out at Cinders. Did a quick bolt check, adjusted the crossover nuts and smashed some whoops. Felt realllly good. Rear end is definitely the limiting factor. Family ride tonight then will find a jump tomorrow![]()
