smokeysevin
- Mar 7, 2023
2001 Toyota Tundra SR5 Access Cab V8 2WD 4WD SC
"if I am going to do the work, I may as well do it how I wanted"
I decided in July of 2023 after getting back from a work trip in Dubai and landing that sweet sweet travel pay, that rather than fix all the annoying things that were bugging me about the truck, I would bolt a range rover TVS1900 supercharger on the stock 2uz. I hilariously thought I could do this for about $5k... so I decided to ruin the reliability of the famously reliable truck. Did I mention that I am an idiot?
Spec overview: 2001 Toyota Tundra SR52WD 4WD
Engine
Elate Manufacturing Intercooled TVS 1900 Manifold (https://elatemfg.com/product/elate-1-2-3uz-intercooled-supercharger-manifold/)
2010 Range Rover 5.0 TVS 1900 Supercharger
Frozen Boost Intercooler Heat Exchanger (https://www.frozenboost.com/water-to-air-heat-exchanger/air-to-water-radiator-p-1063.html)
Cobra Intercooler Pump
SEP Fuel Filter: (https://www.snakeeaterperformance.c...less-10-micron-filters?variant=42384807657701)
Bosch Pro Series 540LPH Fuel Pump: (https://www.snakeeaterperformance.c...sal-in-tank-fuel-pumps?variant=39246934409265)
Bosch EV14 550 Fuel Injectors
Fuelab Adjustable FPR
ASP Underdrive Pulley: (Home - https://www.autospecialties.com)
SSAutochrome Shorty Headers and Y Pipe: (http://ssautochrome.com/level.itml/icOid/1430)
Spintech 3000XL SS Dual 2.25" Inlet, Single 3" Outlet Muffler: (https://spintechmufflers.com/3000xl-sportsman-round/)
Magnaflow 2.25” “Spun Cat” Catalytic Converter: (https://www.summitracing.com/parts/MPE-53955)
Champion Cooling Aluminum Radiator: (2000-2001-2002-2003-2004-2005-2006-Toyota-Tundra - https://shop.championcooling.com/2000-2001-2002-2003-2004-2005-2006-Toyota-Tundra)
HPS Silicone Radiator Hoses: (HPS Black Reinforced Silicone Radiator Hose Kit Coolant Toyota 99-03 Tundra V8 - https://hpsperformanceproducts.com/products/hps-black-silicone-radiator-coolant-hose-kit-toyota-99-03-tundra-v8?_pos=3&_sid=8d6ce3a24&_ss=r)
Ebay Air Intake
Volant Donaldson Power Core Air Filter
Electrical
Switchpros SP9100 (https://store.switchpros.com/sp-9100-switch-panel-power-system/)
MF1050 Air Compressor (MF-1050 Tsunami Air Compressor - https://masterflowair.com/products/mf-1050)
Jim's Machineworx Battery Terminals
1000W Renogy pure sine wave power inverter
GEP PDU/Relay Boxes
Blue Sea Systems Push Button Circuit Breakers
Drivetrain
Transmission/Transfer Case/Driveline
2004 A340F 4wd Transmission
14X5.5X1.58" Dual Pass -10AN Transmission Cooler with Fans: (https://www.ebay.com/itm/224319946787)
Radesigns Winters Shifter with electronic control system (Winters-Elec. Control Kits - http://www.radesignsproducts.com/winters-elec.-control-kits.html)
2000 J Shift Manual Transfer Case
Hendrix Motorsports Billet Aluminum Carrier Bearing: (https://www.polyperformance.com/hen...um-carrier-bearing-support-for-toyota-cbs-001)
Front End
2000 7.5” Clamshell Front Differential
4.56 Yukon Gears
Toyota Supra Limited Slip
ECGS Solid Bearing Spacer
Locked ADD Actuator
94.5 Tacoma Manual Locking Hub Swap
Aftermarket Spindle Hubs
OEM Wheel Bearings and Seals
OEM Manual Lockout Hubs
DTA Tacoma Outer Axles
OEM Tundra Inner Axles
Rear End
GM 12 Bolt Truck Rear Axle
Yukon Heat Treated Axle Shafts
Mark Williams Enterprises Steel Bearing Cap
Mark Williams Enterprises 1310 Yoke
Low Range Offroad Toyota to 1310 U Joint: (https://www.lowrangeoffroad.com/131...t-u-joint-universal-joint-tdi-1310-toyuj.html)
Detroit Tru-Trac Differential
Yukon Gear 4.56 Gears
Moser Bearing Support Diff Cover
Brakes
Brake Hydraulics
Toyota 4runner Dual Diaphragm Brake Booster
T100 1-Ton Master Cylinder
Wilwood Adjustable Proportioning Valve (Wilwood 260-12627: Proportioning Valve Knob Adjust - JEGS - https://www.jegs.com/i/Wilwood/950/260-12627/10002/-1)
LSPV Delete
Wheelers Offroad Extended Rear Brake Line (https://wheelersoffroad.com/shopbyv...eight-to-2-lift-tf-bline-05-red-or-black.html) Currently too short
Front Brakes
2006 Tundra Brake Update
Rear Brakes
Custom Brake Caliper Mounts
2007 Toyota Sequoia rear brake calipers and rotors
Custom hub centering rings
Wilwood parking brake calipers
Suspension
Front Suspension
Donahoe Racing (Icon) Extended Travel Coilovers (Products - Icon Vehicle Dynamics - http://iconvehicledynamics.com/shop/individual-accessories-components/36-2000-2006-tundra-ext-travel-front-coil-over-shock-kit.html)
Camburg Uni-Ball Upper Control Arms (https://camburg.com/shop/suspension...wd-00-06-performance-1-00-uniball-upper-arms/)
Sway Bar Delete
Total Chaos Fab Steering Rack Bushings (Toyota Tundra 2000-2006 POLYURETHANE STEERING RACK BUSHING KIT | TOTAL CHAOS FABRICATION - https://www.chaosfab.com/accessories/2000-2006-Tundra-Urethane-Rack-Bushings-97701)
Total Chaos Fab Double Shear Plates
Total Chaos Fab Spindle Brace
Total Chaos Fab Uniball Adapters and Misalignment Spacers
Rear Suspension
Deaver G57 Spring Over Leaf Springs
Custom Rear Cantilever Suspension
FOA 10” Travel Remote Reservoir Shocks
Airlift Dominator 2600 Airbags
Daystar Air Bag Cradles
G2 1.5” Wheelspacers
Utility
Custom Bedcage
TT Motorsports “Harbor Freight” Jack Skid (TT Motorsports 1.5 Ton Floor Jack Skid Plate and Quick Release Mount | tt-motorsports - https://www.tt-motorsports.com/product-page/tt-motorsports-1-5-ton-floor-jack-skid-plate-and-quick-release-mount)
Quick Release Fire Extinguisher Mount
US Cargo Control "Airline" L-Track (L-Track - Heavy Duty Airline Track Tie Down - https://www.uscargocontrol.com/Aircraft-style-seat-track-6-ft)
Viair 5 Gallon Air tank (5.0 Gallon Air Tank | VIAIR Corporation - https://www.viaircorp.com/air-tanks/5gallon)
40MM Ammo Cans
Tools
Required for service/repair
Recovery Gear
Straps
Shop Towels
Solar Charger
First Aid
Air Hose
12k Winch
Fluids
Oil
Trans Fluid
Diff Fluid
Brake Fluid
40MM Ammo Can Locks
Lighting
Aftermarket “Black” Headlight Housings (http://www.ajpdistributors.com/0001020304to3.html)
TRS Morimoto BI-LED Projector Retrofit (https://www.theretrofitsource.com/bi-led-morimoto-m-led-headlight-projectors-kit.html?preselect=52976,54340,49863)
Nilight 7” LED Spot Pattern Lights
Nilight 2X3 18W Dust Lights
Nilight 2X3 18W Reverse Lights
KC Hilights Cyclone Amber Rock/Service Lights (KC® Cyclone LED Rock Lights / Accessory Lights - Multi-Colors & Lenses | KC HiLiTES® - https://www.kchilites.com/light-type/led/cyclone.html)
Interior
Alpine Android Auto Head Unit (iLX-W650 Bundle with KTA-450 - https://www.alpine-usa.com/product/ilxw650_kta450_power-duo_package)
Firestick Antenna (CATALOG Main Page (Frame Setup) - http://www.firestik.com/CatalogFrame.htm)
Sony Xplod 800w Amp
Kicker S8L5 Subs under rear seat
Infinity Reference Speakers
Raamat Sound Deadner
10.1 Digital Dash Conversion
Exterior
Roadrunner Fiberglass Front Fenders
Pulled Rear Fenders
Custom Rear Hitch
2006 Tundra Grille
Engine
Ebay Air Intake
Electrical
GEP PDU/Relay Boxes
Drivetrain
Front End
4.56 Yukon Gears
Locked ADD Actuator
Rear End
Brakes
Brake Hydraulics
LSPV Delete
Front Brakes
Rear Brakes
Suspension
Front Suspension
Sway Bar Delete
Rear Suspension
Utility
Custom Bedcage
40MM Ammo Cans
Tools
Recovery Gear
Straps
Shop Towels
Solar Charger
First Aid
Air Hose
12k Winch
Fluids
Oil
Trans Fluid
Diff Fluid
Brake Fluid
40MM Ammo Can Locks
Lighting
Interior
Sony Xplod 800w Amp
Exterior
Pulled Rear Fenders
Custom Rear Hitch
2006 Tundra Grille
