Project 69
BROmanian
Ever since I built my first buggy there was always something missing, like windshield, seat heaters, air-conditioning, doors that open and you can get out without braking your back, knees and neck, and of course lots of lights. I needed something like handled like a Class 1 off-road and like a Porsche on the road and that I didn't need to smog, because Cali, big dreams that can't really be reality but a guy can dream.
Anyways, from big dreams Project 69 was born, it needed to be a 69 because obvious reasons that we cant get into since this is a family friendly establishment.
It needed sequential transmission, (because once you have one you just don't go back) high revving V8 with big power and to be street legal that I can drive wherever I wanted. Only thing that fit that bill was a 69 Baja bug so I started looking. Really wanted it to look period correct with lots of light and louvers, we get to that later, with some modern touches.
So I started talking about it at work and one of my coworkers said, I have exactly what you want, it's all there, basically you just need to finish welding and get whatever engine and transmission you want. Hell yeah, I thought, this is off to really good start, I should be done in a few months. Turns out it was a 96, I might have heard what I wanted to hear there. He had purchased a kit that you just send to a laser cutter and they cut everything for you and you just weld it together and voilà you're done, off to the desert and hit all the sweet jumps. I had the same kit on my old buggy so I knew that it works really well so I wasn't worried.
So the saga begins.
I started with the engine because, where else would you start? The block is a 6.0 liter LS2 with the LS3 crank, LS2 rods and forged pistons and 823 LS3 heads. With the Summit racing 8710 cam it should produce right around 540 hp.
The jigsaw puzzle coming together. That Everlast welder better ever last me because we have work to do.
Went to Kartek and bought these spindles only to find out that the design was for some other diameter. Shit balls, luckily I have a CNC machine that can make this hole bigger. After a quick programming and setup the hole was larger just like magic and I could finish the welding.
The test fit went well but where are the shocks going to go? I think he was planning on doing his own shock mounts. Since I have the files, I just sent them out to a buddy of mine and got the bulkhead laser cut.
So I started cutting, turns out this is not the last of the cutting, more to come.
Picked up a 69 bug that will be the star of the show. Started cutting of all the shit that I won’t use.
I really went ape shit with the grinder and got the body to sit pretty good on there. Lies, it fits like shit but that was expected. Time to cut more.
Started with cleaning up the pan to fit the tube chassis. This Harbor Freight air hammer does wonders on the spot welds. Those sauerkraut welds didn't stand a chance, they surrendered like the French.
Built this sweet, super safe, made out of leftover fence material that I had laying around cradle. Flipped it over and now I can build the frame that the body will be attached to.
Pretty proud of this CAD design for the roll cage, I mean even the King suspension is on there.
The body is attached to the frame and the bulkhead is set at 7 degrees. Fits pretty good
