Project 4Skinner: Unclean, uncut, unkosher and unashamed
March 2021
Total Chaos is an awesome company. Their products are robust, fitment is great, and they have a decades-long history of performance and reliability.
New bushings and inner sleeves. Everything got copious amounts of Superlube.
Clearance for upper arm
Effortless install! If you look closely, the frame appears to be welded where I cut it to tweak/beat/coax it back into its home. Since it appears to be TIG welded, I must’ve not filled my MIG bottles… this was still during Covid, so maybe that was my excuse? I don’t remember…
Trimmed out the inner fender with tin snips.
Got shit tacked together for fit check
Made a doubler plate for under the frame VIN. See bottom left of photo:
Looks like I finally got MIG gas, and made some extra gusset templates from beer boxes
Inner fender trimmage on drivers side
Tigged the upper arm shock mount chingadera.
Used the hand template digitizer
drivers side mostly burned in:
Extra shock hoop gussets on drivers side also:
Tidy packaging
Late March 2021
Beers: At least one Coors Heavy as shown in the pics. So realistically probably 6-9 beers.
Didn’t have left hand jam nuts for the inner tierod ends, so I made some out of the stock tierod adjuster. Not only does it jam against the tierod extender, but it pinches also. So that’s pretty fucking cool…
Final result:
Simple & effective. And I didn’t have to drive anywhere or wait for parts.
New moog idler arm and tierod ends. Spares of every balljoint and steering component live in the 4Skinner dezert kit.
April 20, 2021
I decided to shave off the bottom of the front frame rails in preparation for the new crossmember. If I was fucking smarter, I would have cut off the tow bar abortions like this… cutting thru the 1/8” and 0.090” frame rails would have been waaaaay less painful than s-l-o-w-l-y cutting thru the 1/4” plate and welds like I did…. Approach angle is gonna be like 0.69% better this way, so that’s fucking sick.
Trimmed both sides with a sawzall.
Internal frame gussets forged from jap samurai sword steel can be seen here. More on than shortly.
Made bottom closeout plates from 1/8” mystery steel
Inside of the frame rails got 3/16” P&O plate that was welded to some of the stock internal frame gusseting.
***flicks 0.080” jap samurai sword steel internal gusset before welding to 3/16 plate***
“That’s not going anywhere”
Ah yeah! Lookin’ tidy!
Fitting front crossmember. It was either 2x2x0.25” wall or 2x2x0.188” wall.
Lookin’ fairly straight, I burned those bitches in with some fatty caterpillar weave welds
Leia doggo puppers!!!!
Stock bumper brackets had been shittily booger welded to the abortive mess of a front end, so I made new bracketry from what appears to be 1.5x1.5x1/8” angle iron
Evidence of abortive shitty welds still evident here on the right side of the stock bumper bracket:
April 24, 2021.
Bumper brackets
Time: 1.6 hours
Materials: 0.075” (14ga) sheet for the bent bracket and 1/8” HR for the vertical gusset.
Tools: cardboard, vise brake, bandsaw, Ameribrade, MIG, vise grip welding clamps
Beers: since I started at 9:50AM and finished at 11:30AM, I’m guessing more than zero…
If you dont have one of these gems, buy one. They are available from Amazon, Grizzly, and wherever else you fancy buying chinee tools. They are worth every fucking penny.
IMG_0086.jpegIMG_0087.jpegIMG_0090.jpegIMG_0091.jpegIMG_0092.jpegIMG_0093.jpegIMG_0095.jpeg
June 27, 2021
Participants: whitetrashkyle and @h0runner
Dirt miles: 15+
Smiles: 69
Laughs: aplenty
Beers: likely
The 4Skinner performed amazingly. I remember being absolutely stoked on the performance to simplicity ratio.
IMG_0417.jpegIMG_0418.jpegIMG_0419.jpegIMG_0420.jpegIMG_0421.jpegIMG_0422.jpegIMG_0423.jpegIMG_0424.jpeg Anakin Skywalker: “we lost something”
Size difference is fucking crazy! I think this was the maiden voyage for the WTK F150. It got lots more backhalf cagework later on.
Yeah, that’s a JAZ jeepspeed cell mounted backwards atop the stock 18(?) gallon tank.
Simplicity
Double the HP and suspension travel makes a huge fucking difference
First long distance trip
Late December 2021
Up until this point, @FatJeff had been driving the 4Skinner around town, dropping kids off at school, making Home Depot runs, etc. he hadn’t driven it in the dirt, and he had never ridden with me, or anyone else for that matter, in a fast(ish) offroad truck.
We did 250 miles of dirt from Indio to Chiriaco summit, then Bradshaw trail to Cibola, then down the Arizona Peace Trail to Yuma, then thru Glamis up the C-ANAL road back to Indio. It was the first time @FatJeff did any significant dirt miles.
Jeff took it easy, drove pretty slow, and got used to how the truck handled. His son had an absolute blast, learned 14 new swear words, and they slept well in the back of the 4Skinner.
Only issue was the AFM on the stock air box came unplugged after a particularly miserable 22-mile crossgrain trail that @Motiracer38 navigated us through. I quickly diagnosed the problem and Jeff was motive in short order.
IMG_3517.jpegIMG_3543.jpegIMG_3529.jpegIMG_3587.jpegIMG_3556.jpegIMG_3580.jpegIMG_3583.jpegIMG_3584.jpegIMG_3586.jpegIMG_3666.jpegIMG_4491.jpeg
Jeff didn’t feel comfortable navigating this waterfall (they always look tamer in pics), so whitetrashkyle drove the drop for him.
February 2022
Black Mountain wilderness & Hinkley area.
Dirt miles: 80ish
Beers: much to the delight of some of the technicians and fabricators from my work, I rolled outta the 4Skinner crushing a 32oz highlife at 7AM. Count for the day was around 20.
Lunch: turkey sammiches with extra mayo
Poker run organized by an engineer I worked with. I drove @FatJeff around in the 4skinner so he could get an idea how ridiculously hard and aggressively his truck could be driven.
IMG_4497.jpegIMG_4498.jpegIMG_4500.jpegIMG_4501.jpegIMG_4502.jpegIMG_4503.jpegIMG_4511.jpegIMG_4516.jpegIMG_4518.jpegIMG_4519.jpegIMG_4524.jpegIMG_4525.jpegIMG_4526.jpeg
We had a great fucking time.
March 18-20 2022
After the black mountain wilderness poker run, I noticed some disconcerting driveshaft marks on the fuel tank. I was throwing the 4Skinner into corners REALLY hard, and the 12” shackles coupled with soft red Energy suspension bushings were allowing a metric fuckton of side-to-side axle movement. Enough that the driveshaft was aggressively dry humping the gas tank. You can see shiny marks on the tank if you peep between the shock and the spare tire in this pic:
I remedied that fuckery by machining upper frame pivot bushings out of Delrin. New crush sleeves were 0.75x0.120” wall 4130 tube bored to 9/16”
Quickie way to safely hold and machine the OD of some bushings I had:
I have no idea why I’m wearing bitch mittens
Installed with what appears to be boat trailer wheel bearing grease as lube:
Added a 1.75x0.120” Wall DOM brace between the aft lower a-arm pivots at 9:30PM the night before the trip. I don’t painstaking clean all the rust off my tubes like @GahnRacing.
Notice the wet rags removing heat from the bushing assemblies
This trip was supposed to be Adelanto to Lake Isabella, but things changed.
@Dodah and I met the boys @sdecurti @Adventure Endeavor and @believeinbilly North of Adelanto. We went thru Hinkley, saw the F-22 crash site, crossed Cuddeback dry lake, went thru Randsburg, and then @GahnRacing blew a tranny outside Inyokern. Rain was forecasted in the lake Isabella region, so we stashed the broken ford ranger at @Motiracer38 ‘s camp in the Spangler hills area, re-thought the entire trip plan, then made our way thru Trona Pinnacles and skirted the lakebed to a breathtaking camp spot overlooking Searles Lake.
Adelanto
Cuddeback~ish
Looking West toward the El Paso mountains
Cuddeback
Trona Pinnacles
Outside Searles Lake
March 18-20 2022
The next day we trekked thru Death Valley, Argus Range, Panamint Springs, Darwin’s wash, Olancha, cactus flats, and ended up camping at Fossil Falls.
PlannedSon and I both enjoyed the comforts of the 4Skinner both nights.
300 dirt miles
Times I had to engage 4x4: once
Beers: far too many
IMG_5030.jpegIMG_5034.jpegIMG_5036.jpegIMG_5037.jpegIMG_5041.jpegIMG_5042.jpegIMG_5047.jpegIMG_5049.jpegIMG_5052.jpegIMG_5054.jpegIMG_5071.jpegIMG_5074.jpegIMG_5075.jpegIMG_5065.jpegIMG_5064.jpeg
Cheers
