Baconcreekmetal
- Mar 18, 2023
I like that a lot......
This came out badass!!Got the carrier wrapped up. Very jazzed with the final product! The limit strap does not support the tire when the tire is inflated it's only there in case of a flat to prevent it from sucking through the bottom.
View attachment 52699View attachment 52700
Thank youThis came out badass!!
No not at all. If i have time this off season I would like to sell my 12's and get 18's and put them into the cab. I need to do this rear end then set up the entire steering system first tho. So they may remain under the bed for a little bit longer.Are you pretty committed to keeping the shocks under the bed?
I have fox hydro bumps going on right now aswell. I'm starting to think I should just sell these 12's now and make the jump rather then setting up a frame notch and bumps twice.CopyI’ve only messed with coilover valving so I’m not sure if (x3) 15’s is THICCCCC for a bypass. I feel like if you are blowing through those, then 20’s might create some extra heat .
Maybe some 20’s towards the bottoms of the stack would be a good place to start
Are you gonna run a hydro bump?
Ya don’t be a bitch do that lolI have fox hydro bumps going on right now aswell. I'm starting to think I should just sell these 12's now and make the jump rather then setting up a frame notch and bumps twice.
That’s my plan after seeing Danny Gianninis new build I’ve looked at threat motorsports for both wiy and complete always has them on sale tooIMO the short course setup is the way to go if you don’t want to hear bypasses. 3.0x18 IBP or 3.5x18 IBP.
When I was looking at link setups, Jesse Ensign’s setup was what I found to like the most. He runs a Kibbetech 48” link and a 3.0x18 IBP. Wheelbase iirc is pushed back roughly 3” like this.
https://www.instagram.com/p/Cye4M8TLLpb/?igsh=bWdmZmEzMXMweTIw
I'd like to run the single shock mostly for noise and the cost savings lol. This bronco isn't winning any races mostly want it to be more comfortable when carting the family around. I like the idea of the threat single shock trailing arms. I'm leaning towards that set up with @Giant Geoff link pivots.What makes you more inclined to a short course link set up?
Yea I think your right. HahaSingle coilover off the axle is the beez kneez, and exactly what this thing needs Brett.
I wish we could get DR back. There’s a few single coilover stadium style suvs I’ve seen.
