For Sale Ford vehicle part out explorer bronco f250 71 F350 Supercab no cab
85Yota
Ok so I got a few in selling. No titles or paperwork for these except the first one. In Lucerne Valley CA 92356. Buyer to bring tools and help to remote parts themselves like a pick your part.
1983 Ford Bronco have 5.8l auto and t case all removed and for sale along with rest of bronco. No seats, brackets, hood or front frame suspension. I have estate sale paperwork from guy I bought it from so you may be able to get title and run the body but never tried as all I wanted was parts off it. PXL_20230331_213203208.jpgPXL_20230331_194636776.jpg
1994 Ford explorer no motor or trans but still have electric t case and doors and seats. PXL_20230331_213252347.jpg
1989 Ford F250 4x4 7.5L missing injectors but looks fairly complete. Auto trans and tcase which I was told has been replaced before parked because wouldn't pass smog. Has Hanneman fiberglass fenders and 17" aluminum wheels. D50 TTB longbed with line x PXL_20230331_213313866.jpg
1989 Bronco 3" body lift. Missing body parts are in back and dented not very good. Top has paint flaked off and fiberglass exposed with some holes on top from a rack
1985 Ford Bronco was manual transmission but no motor trans or tcase or steering column. No tailgate and modified wider stock tire carrier with gas can mount it appears
1971 Ford F350 flat bed. Rust on pass floor board but rest of cab seems decent. No steering column or steering box. PXL_20230331_213347528.jpg
PXL_20230331_182616732.jpgPXL_20230331_182616732.jpgPXL_20230331_182621483.jpgPXL_20230331_182624958.jpg
1974-79 Ford F250 supercab. Only keeping the cab with doors. Rest is available 1" kingpins dual piston caliper front end. No steering column.
TT pick your parts always has new inventory.
Newest additions are a 95 5.0 f150 4x4 And a 93 4x4 f150 bad 300 i6 motor.
Currently have following with no drivetrain but both axles still. No Bronco Tailgates
88 bronco chassis w/94 truck dash doors and front clip.
88 bronco chassis with 92 body and title
90 Bronco complete body minus tailgate. Aftermarket plate steel bumpers.
89 f250 supercab 4x4 diesel
85 Bronco II 4x4 Manual trans withiut shifter and manual tcase still. V6 Motor has no top end.
Then parts bodys no axles
81 Bronco body no driver door fenders or trailgate
92 Bronco no drivetrain or Axles. Rusted rain gutters but good quarter panels, floor and frame.
69 f100 9in rear, rusty cab doors and fenders.
70 f350 dually cab front and rear axles, 1" kingpin beams misc body parts with rust and dents
90 Crew Cab f350 460 motor fairly complete no axles trans tcase interior or good doors. Decent 8'longbed hood and core support.
67 f100 roller minimal rust on body no vin or title.
91 Bronco dentd up sheet metal good Eddie Bauer Tan top and misc interior panels. No axles or front clip
95 f150 4x4 5.0 with rod knock. Fairly complete extra cab truck. Front end has some 83-86 spindles and hubs with 95 diff axles beams etc. No locking hubs has caliper for cores to use with knuckles on front axle.
93 f150 4x4 300 i6 was 5 speed and manual tcase. Trans ecu crossmember and driveshafts sold. Motor lost cam gear and basically for motor parts and core for rebuild.
1985 supercab f250 diesel body for parts and 6.9L idi motor missing oil cooler and injection pump from motor.
Also have misc parts already removed from trucks. Truck bw1356 manual shift transfer case. Bronco bw1356 manual shift case that lost pump and planetary gears but good case and parts to combine with truck tcase to make manual shift bronco case. D50 TTB front axle without hubs or brakes. 93 bronco front frame with custom tig welded dual shock hoops and coil buckets welded on. 92 Explorer auto trans core needs rebuild. 92 Explorer electric shift tcase.
Basically if you need Ford truck parts let me know and I may have them or will get them pretty often. Located in Lucerne Valley, CA
20240620_072613.jpg20240620_072601.jpg20240620_072552.jpg20240618_104040.jpg20240618_104100.jpg20240620_072613.jpg20240620_072601.jpg20240620_072552.jpg20240620_072535.jpg
F100 and bronco is full width 65" wms to wms. I have no Bronco bolt in housings but realistically for prerunners you need to weld on new spring perches to ditch the wedge pinion angle block and new heavy duty shock mounts too.
Yea i'm not worried about the perches and such more about the width. Let me measure my 8.8 when i get home.
Hey I need the bolts for all the serpentine stuff on efi 351w got any (bracket bolts, alternator, ac, pulley on balancer) I lost mine and need them
I got a box of random bolts from a 90 bronco 5.0 engine thay was torn down and parts were in the back of it. So if you want to come and find the bolts you need kick me $20 and they're yours. If you need the brackets I'll sell you those for cheap
I need the bolts only and I don’t know what they look like trying to figure it out
I have a 95 f150 5.0 with all accessories on it still. $30 for all the bolts you want to from the front bracket on that thing. Then you can organize them in zip lock bags you'll bring to know how they go on your motor.
Can you send me a couple pictures I want to see if the look like the same brackets before I make a trip up there kinda on a tight budget
Smog pump with pulley and bracket and hoses all go together for $100
