I do still run the FOAs on the rear of my raptor.
At this point they work good. I rebuild them build every season, but they do not leak. Its more for me to inspect and tune them.
Most recent rebuild I did these adjustments:
1. Fully deburred the bypass plungers
2. Changed the seal head to their new design.
The new design moves the snap ring grove so the wiper seal sits better on the shock body.
3. Revalved with below stack, and used a 5/8 saftey washer as the clamp washer for rebound to reduce the pivot diameter.
4. Installed new version resivor pistons. The new version is hollow, like a cup the old version is a full slug. New version is much lighter.
New raptor stack: (older high flow fox piston form kartek)
All the shims are either king or SDI, or hand polish/sanded FOA
Rebound:
1.15 -- .008
1.3 --- .008
1.5. ---- .008
1.65 -----.008
1.8 ------ .008
1.9 ------- .015
Piston
2.352 --------- .015 (this is a polished foa shim)
2.3. -------- .008
2.15. ------- .008
2.05. ------ .008
1.85. ------ .010
1.6. ---- .004
1.55. --- .015
1.3. -- .10
1.3. -- .15
Compression
Other thing I do now: lube all the o-rings with a metric shit load of slick-honey moto lube.
Pack the space between the seal head and wiper seal holder with pet/Vaseline.
Pack the top of the bypass plungers with Vaseline.
I use shock seals.com oil.
Anyway yeah still use them and tune them but I do not recommend the "clicker adjusters" they become very hard to adjust with 200 psi of nitrogen, so I recommend the norm Allen key one for FOAs.
As far as not using bypasses and just their 3.5 smoothies, I doubt you will be pleased.
Also the foa bypasses click pretty loud aswell.
View attachment VID_20251109_163808_1.mp4
