89 Toyota - Tiny truck
It’s just a pice of 1/4 plate that I drilled a hole in the middle and spot/rosette welded to the top of the bolt head
BUT I was using it to tighten the bolt and it kept breaking the weld so now I cut a hex pad that is spot welded to the head of the bolt and welded on the bottom side and no problems since
Incredible work. All the suspension and fab work you folks do out west is amazing. I was just watching your 4Runner on an old TW post. Is that the one that Brittain was jumping all over the place?
Thanks, yeah that 4runner worked so good for the amount of shock and wheel travel it had
Did a lot of work making all the suspension pivots super strong front and rear and a lot of time on shock valving
The V8 and weight over the back end was a magic combo
Inside it was completely stock and quiet, prob should have had a roll cage for safety though
May post a build of it, had a build thread but photobucket links got hijacked
photobucket has ruined a lot of threads over the years. Damn shame. A thread on the 4Runner would be great! Very unique build and deserves an archive. Love my V8, lot of potential for an SUV. Couple of them have raced the KOH Every Man Challenge.
Swapped out the fox bumps up front for some sway-a-ways
truck is all shwayed out now
fox bumps probably gonna end up on the front of the grocery runner since it has all fox shocks, would really help the front end at bump with the old school dual smoothies and torsion bars
This poor truck needs a full prep but I just keep taking it out
