88 Bronco
Super clean and rad build!
If you're interested I have WELDED and WIY rear bronco bumper kits. Similar to MZ bumpers.
I have a rear bumper from desolate currently but no brackets to get it off the frame. So may hit you up if i cant get it work
thanks dood
desolate recommended removing a spring till they settle but ill run it, going to crank the front a little bit more before alignment.
You know i really wish i went spring under at this point, im seeing the limitation of the spring over and how the rear shackle actually binds if you let it droop low enough. But that will have to be another phase on this truck cause im broke af now lol
I'm in the same boat. Wish I got the Giant 64 kit from the get go instead of going spring over.
