1991 Explorer
Pretty sure you’re the handicapped one outta the group.
figures. i cant fucking find it now, but i swear you said something like "becuase im disabled or handicapped now" cause of your back thing or whatever. but now i cant fucking find it and i look more disfuckedupabled than i am. if thats even possible.
still love you.
And for my next trick.
No holes, no nails, nothing stuck in the tire. Just started to separate and leak out of the “cracks” 3 years on these tires they all have atleast 70% if not more tread. I DO NOT recommend Kanatis, especially being damn near the same price as others.
View attachment 44521View attachment 44522
isn't "Kanatis" the tire Willis got a sponsor/deal with or something? i thought that was the brand he was promoting here and there?
or maybe it was someone else? but i know that name Kanati seemed to be the "new hot tire brand"....... right?
This thread is gonna turn into documenting anytime I take it out and try and keep up with mileage. Took a quick 30 mile ripper this evening with the wife.
Currently trying to brainstorm some sort of storage set up, loosely strapping just isn’t cutting it having to unload everything to sleep in it.
Broverlander roof racks don’t seem as popular on Explorers as with 4Runners but that’s one option I don’t generally like, but could be useful. Driving a 90’s suv, there’s no way I’d bolt a RTT to my roof considering how much body roll they have already with nothing on top. A Yakima / rocket box on a stock roof rack holds a lot of junk, keeps the wind noise on the highway to a minimum I’d imagine, and is removable when not needed.
Been through a few of them in my day. This one is my absolute favorite though.
My first car was an explorer, so the love has always been there. 93 4x4 i had built from stock over the years, which evolved like everything. I might be wrong but @NODNARB did my 4.5 over ttb on coilbuckets, and I think it was his first ever?View attachment 44167
2wd, McNeil built with with equal length beams. Picked it up as a total basket case, rattle canned it and put some wheels and tires on it and made it fairly cool looking.
My other current one is a 93 4x4, exact trim model as my first one. It’s stupid clean, and I wanted to build this one the way I should’ve done my first one. Will be a clean sleeper like everyone else’s haha. I swapped in a manual trans and manual transfer case, but it ended up needing a motor now. So my buddy is swapping that for me. Since I’m handicapped currently
This one is slowly gonna turn into a nice daily/offroad prelander, as my gold one is going to get 1 ton axles and 40s eventually
Any tricks for the manual swap? I just picked up a 94 with a blown up auto trans looking into M50D swap.
I learned a few things doing it and now that I have everything working as it should, I’ll share my experience/headache. This is gonna be as detailed as I can make it.
Trans-
Swap is straight forward, you’ll need all things associated with a manual trans obviously. Including bell housing bolts, the autos are too short.IMG_0584.webp
The “spacer plate” between the bell housing is not the same for a manual. It indexes the starter differently. You can source one which is hard, modify yours, or I just threw my whole plate in the trash. No issues what so ever. Youll need a manual starter as well ( I tried auto, no luck) you’ll need to either modify your trans tunnel plate or find a manual one. I just cut a hole in mine. You can use your auto driveshafts.
Clutch Neutral Safety Switch. You can either bypass that, or hook it up. It’s stupid easy to hook up so might as well do it. All rangers/explorers come with the neutral safety clutch harness. It’s up in the right side by the driver kick panel/firewall. Grab a clutch switch and it will plug right in like it’s oem.
Wiring-
2 options
“Oem” or quick and dirty get it driving, I’ll give you both!
Oem way
You’re gonna use your auto trans harness and make some connections to the manual plugs. On the manual trans you’re gonna have two plugs. One is the neutral switch on the passenger side, and reverse lights in the driver side. You’re going to connect your purple/yellow and purple/black to the driver side plug to have working reverse lights, the pink and red/blue get connected to the nss on the passenger side. If you’re running the AUTO t case you will need to ground the red/white wire to allow you to engage 4low. Otherwise you won’t use that wire.
Quick and dirty way- hook pink and red/blue together, do not hook up clutch rod/switch at pedal. No nss or reverse lights but you can run it if you want.
Pedal Assembly-
You will need the bracket/assemblywith the brake and clutch pedal. Make sure you get an explorer pedal assembly. I used a free rain gutter ranger one, and the clutch is too close to the brake pedal. You do not need to pull the dash to install the assembly like some say. I pulled the e brake mechanism and everything out of the way on the kick panel. Then fight/cuss that thing into a spot that lets you push the rod/pedals into the gas pedal bracket. It’s gonna be a bitch, but fuck pulling a dash.
Ranger pedals too close. I still drive it though, 🤣
Now….
This is controversial topic among the explorer guys. Some say you’ll need a 1994 manual computer, or you will have 3,000rpm rev limiter. Some say you can’t, I used a manual computer. If you can get a 94 with non egr computer you can delete all the emissions bullshit too.
Once you’re done, go take it for a rip and see how it runs! In my case, the motor decided to spit a head gasket around this time, I wouldnt recommend that. It’s gonna feel like a rocket ship compared to an a4ld tho!
Hopefully this helps! All this info has been a collaboration of peoples info and knowledge on the swap. Mine runs and rips, yours should too!
Once over on the wheel bearings, rotate tires, fix a brake line and making sure everything is legit still.
Took the shit box express out for some night miles last night. Nothing too crazy, probably 20 miles give or take.
Then I woke up this morning about 5 hours later and decided it needed more miles, unsure of how far or where I’m going! So here we are out ripping looking for a good time!
Found an old mining cave and talked to some dudes panning around for gold. They said they haven’t entered it cause they’re too nervous, it goes a few hundred feet apparently! I’ll be coming back with a flashlight and some tools. Maybe I’ll make myself rich!
Buy an explorer, you won’t regret it one fuckin bit.
Nothing crazy to end the day/weekend. All in all between last night and today I racked 93 miles. Im gonna measure from behind the balls and call that 100 miles.
Right before I rolled up here these cute guys in their jeep were “flexed” up on this and taking photos. So naturally I did the same thing cause I’m cute too.
Went and shot some of my guns. My ar-15 and my wife’s cute Glock.
And tucked back home for the night without a single hiccup. I’ll give her another good once over this week cause I think I’m gonna go back to sheep’s bridge on Friday. I love getting this thing dirty
Imagine getting smoked by a chick with a cow Glock. Man card revoked.
Kinda why I bought it for her. The 43x is the perfect size for a purse and if she has to use it, might as well look pretty while doing it. It’s the perfect amount of kick once she gets the hang of it. I liked it, I might end up with one myself cause my .45xd is a bit heavy and big for every day carry in my opinion.
