Whipple Charged Gen Juan Raptor Build
And this is where we are currently. Got the limit straps installed and am finally done cycling the suspension. Now it’s time to give these deavers a proper coating so they don’t rust so easily.
What did you paint / coat them with?
I used a graphite coating called slip plate. It definitely does a good job reducing friction between the leafs. We'll see how it holds up long term. Really don't want to be having to recoat every year because wrestling the springs in place with the coating is a major PITA. So far I haven't been able to scratch the coating off despite many attempts when the spring packs would slide out when trying to install them lol
Been a bit since I've updated this but have made a lot of progress in the last 2 months. The bed cage is complete and fully welded. Trying to pull it out of the bed by myself with limited room in the shop was interesting but not awful. Getting it back in after powder coat will be fun...
Very happy with how the layout came out. Was able to reuse the plate that mounted my jack previously for the jack mount and spare fluid holder. And it's just mounted with tube clamps so if I wanted to change the layout in the future I wouldn't have a bunch of welded in mounts to deal with. The only mounts that are welded in are the spare tire Y strap mounts and the mounting plates for the Kibbetech quick release Pelican case mount.
Next up is the front bumper. I wanted to go to a frame cut bumper because I was sick of killing skid plates in the dunes with the ADD bolt on bumper. The biggest problem was going to be dealing with the coolant tank for the intercooler on the whipple. I also didn't want to spend $2k+ for a bumper that I would have to cut up anyway to make it work. I toyed with the idea of building my own but the rolled main tube was going to be an issue as I don't know anyone with a tubing roller and investing in one for a one-off project didn't make sense. I ended up going with a WIY bumper from KL Fab mostly just for the tubing and then reworked it to my liking to fit my truck.
It was designed to be welded on with the option to bolt on and I definitely wanted it bolted on so I could remove it to maintenance anything on the front of the engine and not have to fight with bumper tubes in the way. Nothing for the bolt on option was included so I had to fab those parts myself. I also had to remake the lower mount at the crossmember as I was missing one of the plates. It was originally 2 pieces that were welded together and I made it in into a single formed piece.
There was a 3D printed template included for cutting the frame which was a good idea but it was destroyed in shipping. Who would of thought that a 3D printed piece wouldn't have lasted in a box with a bunch of tubes bouncing around... I was able to make it work to get it close enough and then needed a bunch of trimming and fitting to get the frame plates to fit correctly. Driver's side went pretty smoothly and the passenger side made me work for it but I got it.
Had to do some clearancing to the skid plate down tube in order to clear the intercooler coolant tank.
Also reworked the skid plate tubes so that the skid plate would be wider and line up with the Baja Designs ONX6 20" light bar. I will be running 4 XL80s and 1 XL racer spot on the top of the push bar along with the ONX6 bar under the push bar.
After I was finally happy with the fitment of everything it could come off for final welding.
Had to make some custom misalignment spacers for the traction bars. Had a chunk of 1" aluminum sitting around so I decided to use that instead of the "industry standard" 17-4 stainless. I hate working with stainless but if the aluminum ones don't last I'll make some out of stainless next winter.
Finally done with welding on the truck so I got the battery and all the modules hooked back up. Got the oil changed and fired the beast up for the first time in 4 months. Now I really miss driving it.
Off to powder coat with everything.
Also got the new tires mounted and balanced. Excited to try these Toyo RT Pros out with the new suspension.
I'm gonna implore you to rethink the aluminum spacers. They tend to mushroom and get stuck in the joints.
We use them all the time on race cars (granted not seeing quite the abuse of an offroad truck) without issue. Even if they do get seized in the rod ends, I anticipate I'll be having to replace rod ends every year so not a big deal.
Picked up shocks earlier this week. Cerakote on the bypasses came out awesome and hopefully the revalve on the coilovers helps smooth out the chop.
Got everything back from powder coat yesterday and started slamming it together. Bumper is on and the bed cage is in. What a major PITA to get the bed cage back in. Amazing how it fit coming out (barely) and then didn't fit all going back in. But it's in and not coming out until I either go spring under or 5 link.
Powder coat came out sweet on the bed cage! One of the race cars I work on has this hammered silver powder coat and I think it looks sweet on tube work.
Alignment is dialed in and she left the garage for the first time in 5 months! Test drive went great and I'm driving it to work this week to shake out any bugs and hope to have it in the dirt this weekend. The new rear suspension setup makes quite a difference even on the street but the biggest difference is removing the front sway bar. Yes, it does roll a bit more but it's definitely not anywhere near feeling unstable. It is absolutely hooked up when cornering and I can accelerate thru the corner. Turn in is insane compared to where it was. There isn't a hint of understeer. It just turns in and sets on the outside corner and just hooks the corner. Also did about double the speed limit on a rough country road and the offset holes are so much smoother now which was one of the main reasons I wanted to remove it. I don't get bounced around when one corner hits a bump or hole. Can't wait to get it in the dirt! Just need to find somewhere that isn't flooded... seems like the entire state of Michigan is under water right now.
The ceramic coat makes washing 5 months of shop dust off a breeze. Didn't even use soap, just hit it with the pressure washer. It was still shiny even with a thick layer of shop dust on it. :LOL:
I'll bet those bypasses make such a huge difference for you. I've been trying to convince my uncle he needs to build his gen one, maybe I'll send him this thread.
