gascapkevin
- May 9, 2023
Ya! That's exactly what I was thinkingYeah diving into the front fender looks good. Red or Dead Fabs Toyota pickup is my favorite exoskeleton truck. Clean and simple.View attachment 35334
I was thinking about this as well, but not sure how I could sneak past them without getting too funky.Also I don't believe in tying the cage to the rock sliders. the rock sliders take a bunch of abuse that I don't like introducing into the cage tie ins and if you wheel hard enough and long enough rocks sliders can become consumables.
Thinking its something in the valve body. Ever since I took it in to swap the output shaft and get freshened up it hasn't been right. I either have 1-2 only, 1-3-4 or it wont shift out of 1st at all.. They want to try messing with it again. I'm pretty over pulling it, but I'm getting pretty fat at it at least lolYou need to find a Trans Pro's to get it done right.
Guessing symptoms are too many neutrals. @vcyota92 had some trans issues and he got them fixed. Maybe it's something like he was dealing with.
No, this is a late 80's all mechanical AOD. So it has the TV cable and governor on the output shaft. Supposedly they are sourcing another valve body and are going to swap it while still in the truck. we'll see.Definitely sounds like a valve body issue to me. These things have so many valves that can get hung up or worn out and cause a lot of issues. Is yours still computer controlled? Dan at Silverfox transmission was a hhhuuuggeeee help in diagnosing mine even though he wasn’t the one who built it. When I have to rebuild mine at some point or change the valve body, he will be my first call.
I'll check them out, thanks!Silverfox does my a constant pressure valve body for those to ditch the pain in the ass tv cable
