UR_Mawm69
you would say that............ fucking prelander guys. should he get a RTT also?!?!?!?I say keep your 4wd truck, will be more utilitarian long term.
16's are going to be way to long for you, even if you had some simple 4.5" extended beams. you'd be fine with 14s.so ya I'm not gonna get it anymore but I think I'm gonna buy these: https://classifieds.ksl.com/listing/79304464
I think some long travel mounts in the front should be ok
Not sure but I’ll look into it! That sounds fun for sureAre there any local off-road shops in your area?
- some shops need help as a parts runner or just someone to help clean up the shop. It’s a great way to get into the off-road scene and you will get a good idea of how stuff should and shouldn’t be done.
Sick man I love the honest feedback I won’t get em16's are going to be way to long for you, even if you had some simple 4.5" extended beams. you'd be fine with 14s.
i know you that you're just an excited high school kid, but just don't go blow your money on big "wazoo" parts to be able to say "you have__insert part name here__ that you're waiting to put on the truck"........... reeeeeeeeeeeeeeeeeeeeeeeeeeeeeeaaaaaaaaaaaaaaaaaaaaaaaaaaaaadddddddddddddddddddddddddddd and keep asking questions.
not hating or talking shit, just saying no, i would not recommend buying those.
Where you located ?Not sure but I’ll look into it! That sounds fun for sure
AH THIS IS PERFECT! thanks so much dawg! I will for sure buy those radius arms and some shocks!Super budget, find biggest diameter used smooth body shocks, install some factory 4x4 f150/bronco coil springs, alignment cams to fix camber.
Find some extended radius arms, Yes heim radius arms are best BUT for a budget and running factory springs get some extended radius arms like Tuff Country 24863 Radius arm Kit.
https://neverenoughauto.com/i-23943...Zh6tlZ4HX3fYe-MYwvFIkbmGmaTgckth5Vnw6Pc&gQT=2
You can run stock pitman arm/steering just make sure to install limit straps to make sure nothing binds on them. For rear my brother ran stock leaf's, flipped shackles and a 2.0x14" smooth body on a simple bed cage and it worked decent.
If you are planning on upgrading it in the future, that's when I would suggest doing new fullsize D44 front and 8.8 rear, heim radius arms, etc since you will use them on the future upgrades too. But with the 3.slow keep it budget to have some fun and learn how to drive off-road with limited truck before going full kill on a prerunner with more power, 4.0 ranger or fullsize ttb with v8
Tooele valley Utah!Where you located ?
Haha this funny, I can tell you’re in Utah from the 2 year thing. Im in Utah countySorry for my lack of fab knowledge but what does truss mean?? Would I need to regear also?
My worry with going to tall is I would need to change the driveshaft length… would the bed cage affect that at all?
I will go with any used premium shocks I can get my hand on haha! Thanks for the advice on measuring too, I’m gonna probably get some new bump stops maybe FOA but we will see.
I will do my best with the fab stuff! I secured access to a welder just barely from a friend leaving for 2 years so that’s gonna be free! Thanks for the help so far!!
I would look for a used autofab or even older fabtech kit for the front. if you build the suspension too much, the truck will feel even slower.Hey! for starters, I'm a beginner to the offroad/truck building world but I've got a manual, 4wd, 1994 ranger extended cab. It's got the slowest 3.0 known to man becuase of a misfire that I don't know how to fix. its got minor body damage so its a good platform for a cheap prerunner build. I don't need to race or do anything crazy I just want to be able to hoon around with friends and do desert runs nearby so an overthetop build isn't needed. I would like to know though, what is the bare minimum I need to do to make my truck fun offroad?? I want to be able to take small jumps and basically get the best bang for buck out of it. Any ideas?? thanks in advance![]()
