tie rod material
Doubleggregg
Winchester, Ca
I am looking to use 1" x .250 wall 4130 tubing for tie rods. One end will be 3/4-16 threads so there will be .156 wall thickness1.125 at the threads other end will be M20 x 1.5 so there will be .136 wall thickness at the threads.
Should i bump up the OD of my tie rod material to 1 1/8 x .250 wall?
this is for a arm suspension not long I beam tie rods
Gregg
I've only ran thicker .360 or .375 tubing for beams because the tie rods are much longer and will deflect and potentially stay bent even more.
