The BRONKY (1994 Bronco)
Pulled the bronky into the garage to add a fastener to the valence and found this crack in the exhaust! IMG_6533.webp
Cleaned up the area and welded up the crack. Also did a once over on all the front end and found one loose ttb mounting bolt, yikes!
TBH kinda wish i hadnt welded the crack because it sounded sick before and now is alot more tame :ROFLMAO:
Thinking about adding a flange after the first cat and playing around with exhaust setup running only one cat
Pulled the bronky into the garage to add a fastener to the valence and found this crack in the exhaust! View attachment 30922
Mine has never had a cat since I've owned it and I am going to add a second muffler just because how loud it is in the cab with the drone. So the tameness may be nice haha
Started working on the front skid plate. One thing a day, so today i worked on the mounts for the lower part of the skid plate. The plan is to make it 100% bolt-on. IMG_6662.webp
What do you guys use to cut sheet metal aside from a plasma cutter? Been using an angle grinder for a long time but want to see if something else will cut a little faster and less sparks.
metal cutting circular saw to get the the piece off my big 4'x4' sheet then tune it in on the band saw like the one linked above.
Yeah, it really is game changing. The trigger on my m18 Milwaukee one is kind of wonky, I have a replacement to see of that fixes it. Otherwise its an awesome tool. I'd buy another one if the saw turns out to be bad.
Finally got around to building this skid plate LOL. I am building two trucks at the same time (I am autistic) and decided to build this bumper while I wait for motor mounts for my 4.0. SOHC swap in my ranger.
I actually built a V1 Skid plate but it had really bad welds and I wasn’t happy with how it came out at all. I got a 240v outlet installed in my little shop (the garage, but it’s all mine) and got some setting recommendations from the instagram welding pros. Happy with the results this time around 🤌🏽
My friend gave me a cool canopy and I’m stoked on it! Will be nice for spectating races down in Mexico. Wasn’t able to make it to the 400 this year but there’s always another race.
Want to build a roof rack to mount the canopy and for more storage. Can anyone share designs for ones they’ve built? I really like the old desolate ones but haven’t been able to find anyone selling one
No fun mods recently, still chipping away at my 4.0 SOHC swap in my ranger but made some time this past weekend to install new U joints in the Bronky rear driveshaft. Had recently started to get shuttering when taking off from a stop so figured it was the u joints since the trans was rebuilt last year. Truck drives so smooth now, was a great reminder that maintenance is important and cool suspension mods arent everything haha
