The BRONKY (1994 Bronco)
Pulled the bronky into the garage to add a fastener to the valence and found this crack in the exhaust! IMG_6533.JPG
Cleaned up the area and welded up the crack. Also did a once over on all the front end and found one loose ttb mounting bolt, yikes!
TBH kinda wish i hadnt welded the crack because it sounded sick before and now is alot more tame :ROFLMAO:
Thinking about adding a flange after the first cat and playing around with exhaust setup running only one cat
