charlie brown
- Apr 4, 2022
whats the differents? pro/cons?
![]() Bill Sonevongxay | Forum Sales And Support Baja Designs | 2950 Norman Strasse Rd. | San Marcos, CA 92069 Phone: +1 760-539-3469 | Email: Bill@bajadesigns.com |
![]() Bill Sonevongxay| forum Sales and Support | | |
| 2950 Norman Strasse Rd. | San Marcos, CA 92069 | Baja Designs: 760-560-2252 Email: Bill@bajadesigns.com |
Hey @thebodj
Correct, from the control module to the switch panel it's connected by one RJ45 cable.
Best,
Bill
Bill Sonevongxay| forum Sales and Support || 2950 Norman Strasse Rd. | San Marcos, CA 92069
Thats the problem with an SP, the cable for the switches can not be touched via there warranty… id much prefer the ability to change and determine my own length as well…Hey @JACKSONRALLYINC
The RJ45 holds up well for its use. We have not seen any damage to them in many scenarios. This cable is used so that way it's easy to fix when it needs to be swapped out and it creates a user-friendly diagnostic. If you are worried about the cable there is an option to run their BantamX & SourceLT completely Bluetooth utilizing their app.
Best,
Bill
I used a switch pros to run my ranger. I had the ignition, fuel pump, starter, and radiator fans to it. Super easy to hook up. i did run the radiator fans through relays just because they pull a lot of power. The ignition and fuel pump and all that stuff was ran directly to the switch pros. It’s easy.Can someone point me in the right direction or give me some info on using some SPods or Switch pros to run my whole truck? I hate wiring and want it to be as simple as possible so my pea brain can add or work on it.
Short story is the engine will be managed through a holly dash and computer/harness.
One panel id like things such as, ignition, rad/oil cooler fans, etc that has to do with major components.
Second panel to control things like lights, blinkers, windows, etc.
The truck will be very bare bones street/race turk. Not alot of creature comforts, so 2 panels would be more than enough.
Tell me if im dumb or not, or what else i might need to pull it off.
Much appreciated. I’ll check this out and read up on how it all works. If I have any questions I’ll reach out.Hey @Flapjack935
With any sPOD unit, it will help clean up any wiring in your engine bay and make the process that much easier. We have 2 different styles of units which are the SourceLT and the BantamX.
For the route you are going with, I would suggest checking out the BantamX. With this unit, you are looking at an 8-circuit unit rated at 30 amps per circuit which will allow you to run 100amps at once. While the unit usually sits in the engine bay there's an (RJ45) Ethernet cable that runs through the firewall which powers an HD, Touchscreen, or a Rocker Switch panel. You also have the ability to run everything off your phone since this unit has built-in Bluetooth. Another key thing I would like to highlight is that you could link up to 4 units which will allow you to gain up to 32 usable switches. I will go ahead and provide a link to this unit, if you have any other questions please feel free to reach out.
sPOD Units :
- BantamX HD – Universal
- SourceLT Modular – Universal
Best,
Bill
Bill Sonevongxay | Forum Sales & Support
Email: Bill@bajadesigns.com Phone: (760)560-2252
