Doubleggregg
- Jul 27, 2023
Looking for a smoke machine to help chase vacuum leaks. Any recommendations?
i need to go up in the next couple weeks to drop some stuff off for josb, i thinkif adam is coming up to the high dezert anytime soon you can borrow mine. or if you are up here anytime you are welcome to come and get it.
I know this trick, rpm didn’t seem to change when I sprayed it at the brake booster / master cylinder seal. But I have done this and seen results when the vacuum leak was closer to the intake manifold.Spray a little brake clean next time in the area you think is leaking while the rig is running. If rpm changes, you found the issue.
