RSS Shop Bronco
ive done absolutely nothing on the bronco until like 1 month ago. I impulse bought solo pivots, fk and 1 China rod end, and a desolate 3/4 cage and converted some hella 9000s to LED on the bumper with amazon bulbs and they work great on the side of my house. Waiting on the cage to come in and deciding how big of a notch to go with, how to tie the cage in and what shock size i plan on running its a short course link but laying the shocks back parallel to the back seat.
Took a day off to work on my stuff made some solid progress should be done with another 2 days of work. I’m going to run it as a 3 seater and maybe keep it on leaf springs for the time being I have everything to link but also want to drive it.
I got a cheap Cho spring under kit installed it mainly at night , going to do a Cho c notch and put on some 2.5x2.0 bumps I got from a customer I only have one so if anyone has another random single I’ll buy it. IMG_9730.jpeg5F0384D3-D776-4E4C-A593-4442A547EC0B.jpeg
How do the raptor shocks do in the rear?
Did you re-valve or just run it?
They work pretty good I revalved them once and then never did anything else to them for like 4 years, I’m going to need to Revalve them again for spring under but realistically I’m going to run it as is for a while because I feel bad working on my own shocks vs customer stuff
If you're ever in the mood to post how you set them up I wouldn't mind. I'm going to use them on mine also. Someday.
The base valving is decently close for a spring over set up as long as it’s cycled clean all I did was add a small amount of rebound I think because the back had 0 weight at the time
