Noah's Long Travel'd 4x4 Silverado build
RadoNoah
My name is Noah i am also known as RadoNoah
Truck Information
Model: 2007 Chevy Silverado Classic 4wd Z71
Engine: 5.3 L59
Transmission: 4L80e W/ 2800 stall Cicle D Converter and Trucool 40k Transmission cooler
Body/Exterior: Extended Cab Short Bed
Suspension: Front: JD Fabrication 4wd gen 1 Long travel kit, Carbon 2.5x10 Coilovers and 2.0x2 bumps
Rear: 9.5" SF 14 bolt, Deaver F87, CWF Shackles and hangers, Bilstein 5100's
Exhaust: Speed Engineering 1" 7/8 Long tube headers, catless Y pipe and Magnaflow dumped before axle
Wheels/Tires: 17" Method Double standards custom powdered purple on 35x12.5 Toyo MT's
Electrical/Lighting: All bulbs converted to LED, All on mod. Rigid 28" Combo bar, 30" Midnight pro, 2 spot pods up front, 2 Flood pods, Rear facing amber and SR-Q Reverse lights
Sound system: Pioneer AVH-200 deck, 600w Diamond audio 4 channel amp powering 2 DES 6x9's up front and 2 5.25 in the rear, Cerwin Vega 1000w amp powering Diamond shallow 12"
Performance: Full bolt on's and 91 tune by Aaron at All Out Tuning
Build: As of July 24 2022
The day I got it 5/17/18
Truck had a exhaust leak from in between the manifolds and y pipe, I've always wanted long tube headers so decided that this was the time. Did the headers and got it tuned. completely changed the way the truck drove for the better.
This is where things really start hitting the fan, went for a quick impromptu night wheeling trip with friends. Truck was running great so much more fun with tune and trans tune till I decieded to rip some doughnuts. I slowly watched my oil pressure drop from a good 45 to 0 real quick. shut it off, checked to see and i was good on oil level. started it up and no oil pressure. flat towed it home, washed it off and started ripping the motor out.
Decided to get a stock crate 5.3 straight from GM,
Back up and running, put the rough country 3" blocks in since it didnt have the factory 2" when i bought it. Still could not get the leveling keys in (crusted in place). Got my new toyo tires mounted and balanced on the methods.
I
Went out on another late night desert runs...
Made it around the whole planned loop of box canyon, probably a 2 hour trip through some desert and some rocky stuff. Got on the exit road and got a little over confident. Then disaster struck, thankfully everyone riding with me was ok. I underestimated a turn coming in way too hot. panic braked locking up the front tires, at full steering lock did nothing but kept me sliding foward, gassed it at the last second to keep us from wrapping it around a power line pull but still clipped a tree
The axle housing had the tube pulled out on the passenger side, causing the truck to dog walk, so that was one of the first things on the agenda to get fixed. A buddy had a housing that he swapped all the gears out of when he blew up his diff. so we got my gears into that housing, swapped my brakes over and threw it in.
Everyone signed the rear door, like a hs yearbook
Found a bed on Facebook market place for $500 that was the same color.
I
Found some doors at a junkyard the same color off a GMC, took it to a bodyshop to get them hung because the mounts were slightly tweaked
I
Finally got the rusted keys out and the leveling ones in and it sits better.
Mazzulla Rear bumper
After 2 smoked 4L60's it was time for a 80 swap
Little jump
Then smoked another 10 bolt so swapped in a sf 14 bolt out of a late 90's "heavy halfton"
URL]
Glamis with fresh rubber and a splash of purple
Picked up a camper shell for future Prelandering
KDS Fab knocked out this hidden hitch for behind the plate of the MZ bumper
Deaver F87 and Cwf shackles and hangers install
Ripped one of the fender flares off so pulled there rest off before the soon to come glass
Pulled the bedsides, mounted front fenders and cut the frame horns so KDS could get me hooked up with a bumper
Up next was Install of the JD Fab long travel kit with Carbon shocks done by KDS Fab
Thats where it sits now, theres a lot more to come in the near future! Like what could these 3.0x16 Carbon coilovers be for?
Well... things have happened since the last time posting here,
First off had quite a night run ending with me breaking on a flat graded dirt road, the last mile to pavement. I think the bolts came loose on the cv adaptor so that swung around and got a little roughed up
IMG_1161 by Noah Peruch, on Flickr
So because of that its only right to take it to Kds and tear it all apart
IMG_1434 by Noah Peruch, on Flickr
Last time its on all 4 for a while and leafsprings
IMG_1449 by Noah Peruch, on Flickr
IMG_1458 by Noah Peruch, on Flickr
IMG_1520 by Noah Peruch, on Flickr
Decided to do a wishbone 3 link, keeping factory frame rails as well as gas tank to keep it emissions legal and costs down, later a leafspring style bedcage will come, we had everything moc'd up with very little pinion plunge and angle change. everything as of now is currently torn back apart getting fully welded out and beefed up.
IMG_0013 by Noah Peruch, on Flickr
IMG_0014 by Noah Peruch, on Flickr
IMG_0019 by Noah Peruch, on Flickr
IMG_0011 by Noah Peruch, on Flickr
IMG_0007 by Noah Peruch, on Flickr
IMG_0006 by Noah Peruch, on Flickr
IMG_0100 by Noah Peruch, on Flickr
IMG_0016 by Noah Peruch, on Flickr
IMG_0084 by Noah Peruch, on Flickr
More to come soon!
Hell yeah dude. You have a lot going on there.
I love the backstory of all of these trucks. Even the early version of your truck 'looks' simple at first but there is so much work to keep these things going and progressing.
I was wondering the same thing. I am leaning towards a 3 link with panhard bar but if this has held up okay I may consider that option too.
Be careful using a triangulated upper third link AND a panhard bar. Being triangulated it won't want to have any lateral motion. The panhard bar has lateral motion inherent in the way it arcs. I think using both of them will cause binding
I’m wanting just a third, non triangulated, link and a panhard, but still curious how his set up faired
Biggest issue you’ll see is the third link is mounted off of center from the third member, so it’s a tall mount with a lot of torque on the axle tube, causing it to crack or twist the tube in the pumpkin
Been a while since ive been on here, along with a while since ive touched my truck. Stripped it for a cage spring of 24 lost interest in it for a year and all motivation to work on it. Ended up dropping it off at a members shop to have it done. Other than a couple small things im overall happy with it. Itll keep us safe and its a toy
I have no desire in running a LT kit anymore, itll be up for sale. Going to transition into a kinda do it all play truck, get back into the rocks and all
So the Kit will be up for sale along with all the ifs is getting ✂️ off.
A buddy is building me out a aam 9.25 out of a 3g ram to stuff under it. Already have some 3.0x14 bypasses up front. Looks for matching 2.5co and some 2.5 bumps.
Going to have to relocate the fuse box and looking into doing a remote brake booster. Hoping to have 7-8” of up travel from ride height without it being monster truck high.
How it sits right now, need to finish getting the dash fit up but its been tough having motivation with it being 112+ the last few weeks IMG_8341.webpIMG_8411.webp
Awesome cage Noah. I know someone else that went through a change of use dilemma. I'm glad you're moving forward and pushing through, keeping another cat eye out having fun. Plans sound kick ass and versatile.
ive almost bailed and tried to sell it a few times haha. All the trails around me turn into rocky playgrounds, most of my buddies stuff is geared towards it so might as well turn this into something ill get more use out of, the turning radius and low stance of the kit makes it hard. And should still do ok at the go fast stuff i enjoy.
You sure you dont want 16's? lol. I have some for sale. How much did you pay for those, if you don't mind me asking? New from Fox, or a classifieds find?
