Let's see those Bad Lines!
Nut could have backed out but if it did it was very little. Taking it off with my impact it still struggled. Speedway says with the solid spacer they install in it that it’s only 160flbs
This is probably 2012ish
Not a bad line, more of a result of poor planning and a lack of prep.
The pivot bolt on the rear arm backed out on the trail, just my dad and I in the car. No other vehicles no radio no cell service.
we had to walk the trail till we found the bolt.
I didn’t have a jack so we removed the front tire and coil over, dug a hole to drop the front end in which would raise the rear end, pull the rear coil over and ratchet strap the arm back into place…. And of course I don’t have the big ass Allen wrench to tighten that pivot bolt. I probably got it close with a rock and channel locks 🤣
Then reverse order to get home
I carried a lot more tools and took prep a bit more serious after this trip.
To be honest I rarely was able to drive this car back on the trailer 😅😭
Bumpity. last few months...
