Doggo assisted with mounting my new Cutless Designs dome light housing. Looked awesome but didn’t work, which was weird..
..found the culprit, door sill plate screw rubbing thru/pinching the harness and melted almost all the wires together. Cut everything apart then reattached them with different sized butt connectors but all the same color replacement wiring to absolutely confuse the shit out of future me. (It’s all I had available at the moment).
Yes my cab floor is filthy. This truck’s number one job is and always will be doing ranch truck things so it stays dirty a lot. I’ll vacuum it ..eventually.
Super happy with the output of the diffused lens cyclones. Very bright but I feel like the lenses soften it up a little so it’s not so overbearing.
Re-mounted my TT Motorsports floor jack mount and skid (thanks Tommy). Yes I kept the release handle facing the bedside, it’s so I don’t break it off sliding lumber or firewood in and out of the bed. Also slapped on some late model ford factory tie down points from a decommissioned truck at work. Positioned them higher on purpose for when I need to secure taller/lighter loads using a bungee net.
New ac compressor, accumulator, low side pigtail, etc from Rockauto. Nice to have ac again.
Drove it to work for the first time in a few months, an EMT I work with parked his ‘95 behind me. He’s got a rad old school setup with what I think is old Camburg bushing radius arms. His truck is 2wd with a 300 six and a 5-speed. The back of his cab is converted into one larger jump seat that folds into a sleeping platform.
