95_Bluwhale
- Jul 24, 2022
Summit headers are ok I put a e303 cam in my 5.8 but I have maf no real difference in power so save your money and just gear it for your tires if you haven’t you’ll be better off
Negative, I just dropped a new crate motor into it.Are you scrapping that ambulance?
I read certain years (01 among others) of the super duty boxes fit 150/broncs. They have 4 bolt covers, Like the one in that ambulance.
Looks like you have to many vehicles! LolHey dude! Glad to see you here. As you can see I have not made any notable progress on my f150 since I met you in Anaheim![]()
Ended up sticking with the stock spec cam, and I got a set of used pacesetter headers from philo. Yeah regearing would probably be a good idea anywaySummit headers are ok I put a e303 cam in my 5.8 but I have maf no real difference in power so save your money and just gear it for your tires if you haven’t you’ll be better off
Hah! I’ve always had too many vehicles and not enough time or money.. cuz ADDLooks like you have to many vehicles! Lol
Yeh that was a long time ago! Did I buy explorer front fiberglass from you?
Got one TK-980, one TK-8180H-K, and three TK-8180-K’sWhat's the model number? I like to nerd out on this kind of stuff and can research it for you. I just did this with an old Vertex radio.
I hadn’t really thought about it much, but I’ll shoot you a DM. I already power probed them all and every one powers up, and all use the same two wire power/ground pigtail which I got a couple of spare ones. No antenna wiring, brackets, or mics tho yetShoot I'd be interested in one of the four from the bottom picture.
The TK-980 doesn't operate in the correct frequency range and the TK-8180s are a UHF radio, not compatible. You need a VHF radio that operates in the 136 to 174 MHz range. This is based on my limited knowledge of radios. I think @SteveG can chime in with more technically accurate info.Got one TK-980, one TK-8180H-K, and three TK-8180-K’s
Thanks dood. I hit up PCI out of curiosity and this is what they told me, might send out a couple to be converted to GMRS.The TK-980 doesn't operate in the correct frequency range and the TK-8180s are a UHF radio, not compatible. You need a VHF radio that operates in the 136 to 174 MHz range. This is based on my limited knowledge of radios. I think @SteveG can chime in with more technically accurate info.
