GM E-rod LS CARB motor in a ranger?
Not with it imo, too many loopholes to take advantage of. Referee is going to tear you apart for everything. If you do go through with it, I’d recommend talking to whoever is going to do the inspection first.
are you considering doing this for smog reasons? from what im seeing your asking about installing a carb compliant Erod motor into a Ranger and stay smog compliant?
Agreed on above- to get it done legit and fully pass smog with no issues is going to be a nightmare, and that only covers the engine side of things- not considering the fuel side of things with charcoal canister and filler necks and all that BS. Plus those Erod motors are 12-20k.
Plenty of other loopholes to work through to run whatever engine you want.
