97 Jeep TJ
Endless Trails
I figured I should start a build thread for my son Shane's Jeep. This way I can keep the thread for my Megacab just Megacab stuff.
Shane bought the Jeep May 26 2023. It is a 97 Jeep TJ 5spd. As it came it was on 2.5" lift, stock arms, junk shocks, stock alloy wheels, 33x10.5" BFG AT tires, 30/35 axles with gears and lockers.
The price was good but it needed work right off the bat. We ended up putting all new steering linkage on it right away. We went with the stock Grand Cherokee stuff as it is slightly more beefy than the TJ stuff. It still had some handling quirks and we found the rear track bar bracket extension to be loose. After tightening it and it coming loose again real quick, we welded it directly to the axle.
It is good being the son of someone with rad friends and part Point Mugu 4x4 club with cool members. He got some hand me down steel wheels from Ryan Fenner, got some real nice arms from a club member who went to long arms, and found some Cooper 33x12.5x15 tires on market place for a good price.
He switched to a Bimini top when the rear window zippers failed. He took advantage of HF sale on winches and grabbed a 9500 Badlands and a winch plate. We had fun moding the winch plate to work with the stock bumper and sway bar. The swing out on the rear bumper was real loose so it came off and the tire went in place of the rear seat. I think That brings us to the present.
I had borrowed his jeep to do the annual Lockwood Valley trail cleanup / clearing. What a difference driving that up the trail vs my 160" wheel base Megacab. :ROFLMAO:
But packing stuff on top of the tire didn't work well. So we built this wood platform before going up to Monachee.
He has been wanting to put a real cage on the jeep for a while and we found one on a jeep getting scraped on market place. It has all the bars in the right spots and the price was good with belts and a good clean PRP rear bench. It came out of a TJ so how hard could it be...
We after stripiing the dash, steering wheel, and center console out we finally got to try and get it in place. Only to find out the trans tunnel is in the way. I don't remember the one we pulled it out of having a cut tunnel so I don't know if it is a model year difference or manual to auto tub difference? After cutting the tunnel and notching the dash we were finally able to get it to sit on the floor. Only took 4-5 times of lifting it in and out.
We are going to sheet metal it back in, but we have a few more things to do before pulling the cage out again.
Still to do:
Finish other windshield frame pocket.
Sheet metal in the trans tunnel.
Cut out seat brackets (built for PRP seats, Mastercraft seats have wider mount points)
Remove cage to drill mount holes.
Weld in seat mounts and finish weld other stuff on the cage.
Paint the cage
Bolt down cage
Figure out the dash notch behind the vents.
Hope all the dash stuff works when put back together.
I got the other pocket fit and welded. I started on the trans tunnel notch. Need some more abrasives. Need to patch in a few spots that the big pannel missed. Shane should be welding all the spots on the cage that the previous owner skiped today.
Nothing finnished and crossed of the list but a few things are closer.1000024811.webp1000024810.webp
Trans tunnel notch.
Drivers side windshield pocket
Re-notched the seat brackets to sit lower for Shane's 6'7" cranium clearance.
Shane got them welded back in after we figured out spacing to the B pillar with the seats bolted to the brackets.
It should be primed and painted when I get home today. Hopefully we can drop it in the tub for the last time this afternoon.
Cage was set it, but then we pulled it back out. It would have been a shame to do all the work getting the cage in, only to have the floor look like trash. So we pulled it back out, bought a gallon of roll on bed liner and coated the front tub floor area.
Fitting the dash was "fun"... but it came out good. The other fun was that the cage had to lower at the same time the dash was put in place. It was a not fun puzzle of making sure we didn't get ahead of ourselves.
We still need to fix the seat sliders. The crossover cable is gone. And we were short 4 bolts on the cage. Still need to tie the cage to the frame down the road but it has 3/8 5×5 pads on the bottom side of the tub to tie into Getting those to fit sucked.
Also need to find a cheep clamp style rear view mirror that attaches to the cage.
We did a lap around the block. Still need to finish some accessories wiring. I want to build a center console for it with cup holders and switches. The factory one no longer fits between the seats. But that is a later project. I need to get back to a trans swap on my truck.
View attachment 42052View attachment 42053
My dog right here!
What 2.5” lift is on that thing? Thinking about buying an ‘06 TJ off my coworker and I like how Shane’s rig sits. I’m already considering budget-ish suspension options if I keep the stock control arms on the ‘06 if I do buy it
I have no clue which brand. The track bar looks to be Rubicon Express. We got new arms off one of the other PM4x4 members when he went long arm. We had to weld the rear track bar adapter to the axle since we couldn't keep the bolts tight. There has to better springs out there. These are a little on the stiff side, but do flex well.
Built a cargo basket that rests on the cage between the B and C pillars. The wood is temporary, but it it will work for the Lockwood cleanup weekend. All the metal is from a side of the road bed frame, including the key hole stock for tie downs.
Next project will be to get the spare back on a swing out and build a rack over that as well.
@in4aride
I would love Shane to get tons under it, but we will look for a rear 44 at the minimum. He is way more responsible than me and doesn't spend a bunch of money on his toys.
Simi Valley.
@in4aride
Simi Valley.
Damn I wish you were closer. I've got a front JK Dana 44 with an Ox locker and the rare parts ball joint s*** and truss and all that stuff that I'd give You. Pulled it out of our old race car.
