jonsangel
I TIG welded my steering components and added doubler plates to my motor mounts
I get decent TIG beads every once in awhile. Don't zoom on any other of the welds though haha
Now I gotta figure what the heck to do with the pitman arm design. This is obviously the mock up but it's awkward adding the double sheer tab while still allowing clearance for the nut socket. I got the solo motorsports output shaft support which also makes it tricky.
Xxxx
I like that, thanks turboyota! Anyone have any tricks to get that bend next to the notch without screwing up the points? I might have to partially cut the notch, bend, then cut the rest of the way. Not sure if any of that makes sense
I made the tie rod that goes between the swinger and ...the other swinger
Before (that's dye, not blood)
After
Xxxx
Fuck yeahhh. took close to an hour to sand but finally got the bump can sanded out. What a pain. I used the small barrel sander at the welds then I made a big barrel sander just shy of the ID using aluminum stock and a shoulder bolt with the head cut off. Fits pretty nice now though. I need to take the internal spacer out so it has more travel. Should I do 3" or 4" length? I'll probably end up with 19.5" of travel bumped and strapped.
I'm about ready to drop the motor in for hopefully the last time so I stripped everything off the frame to start to paint. I won't paint the top of the engine cage because I still have a bunch of stuff to mount. Anyone have recommendations on undercoating for under the cab and the firewall?
Pile of paper weights ready to paint
Xxxx
Nothing too exciting but made some plugs for my snouts until I get 4WD working
Xxxx
Mr @the bodj came over today and we got a ton done. Kevin killed it. It feels like I just skipped ahead a few months of progress. All the remaining fab work that i needed to complete before dropping in the motor is finished. I just need to do some painting
Mounted the steering box
Boxed in the swinger mount and finished the ram assist mount
Xxxx
After
Xxxx
Xxxx
Xxxx
