2wd f250/f350 suspension; what’s out there?
Oh4Tahoe
Mesa, AZ
Contemplating a truck setup for a potential weekend work truck and mild adventures rig. Dentside and newer OBS trucks what’s out there for 2wd suspension to gain some travel and height?
Is there any good suspension stuff out there for 2wd super duties?
@Giant Geoff , how much travel does that stock beam setup pull?
How much width does it add?
Is that stuff on your site for research purposes?
The basic kit with the stock beams, you can widen 4 inch and 6.5 inch with the holes I’ve made in those brackets
The equal length kit starts at 5 inches per side and you can go wider depending on what you want.
Both these kits only work with 99 to 07 trucks.
https://www.giantmotorsports.com/product-category/i-beam-kits/super-duty-eq-beam-kit/
I have a bolt on Engine Cage that is not on the site.
Hey Geoff, any plans to make this same thing for newer 2wd F250/F350's AlumiDuty? I have a 2019 F250 2wd and nobody makes lifts for these things.
I really wanted to make the 2020 Alumi-Duty kit, but all the time I spent on it was a waste to try and resell it because the guy wanted to run 42 inch tires with a low ride height, and once we jig up those beams and made crossover steering based off of their center steering garbage (see how I did cross over off the stock draglink). We made a set off the fixtures for another customer with a normal size tire and it sat really low and scrapped trying to offer it.
Hi Giant.
I’m looking for a set of drop down I beam brackets for a 24 F-250 gas. Any suggestions?
I’m now working on a 3-4” drop bracket for the 2012-2026 F-250 with some help from here as we speak. How much lift are you looking for?
