DialedShockPrep
- Jul 5, 2023
Well that makes things significantly easier than!We might need to chat soon and willing to pay for your time to look into things…
Also you may not have seen, Cho and Jonny are making a ttb set up for Jonny 4wd 2011 f150 right now.
I’d go that route. I could be wrong but you should be able to run just about anyone’s Dana 44 beam set, and factory spindles if you wanted to. There’s ways to do this more cost effectively parts wise as long as you can reasonably get the frame/engine crossmembers/beam pivots done without a full one off deal. I’d put money on you being super content with the truck if it had 18-19” front TTB travel, your spring under rear, and a day spent fine tuning the shocks. That setup will work incredibly well and be super comfy in the cab.
