trying to get the motor running this weekend
2010 mercury milan 3.0l duratec with GT3582 turbo
after it runs i can wire up my trans. 6hp26 and arcade paddle shifter via Arduino
for now i am rhino lining the front with a can of rustoleum
FYI 2010 Toyota sienna coil on plug fit right on a ford 3.0l duratec
tested at 10K on the Arduino!
cant trust the colors china put on the pigtails at all though
this is about as good as i get
put the individual powers to the coils on the right and injectors on the left.
the fuse blocks are oriented to the v6
when/if one melts down to china i can see what cylinder it is
still need to get some grommets.....
made a wire frame to hold the fans
the plastic shroud was a couple inch's too thick to clear pretty much anything in the car
if i get bored some day i might make a more engineered shape
got the muffler mounted in a tight little corner
poked right out the shark fin
maybe 3/4" tire clearance
trailing arm 56% chance of rub at full crush
moving on....
