winters shifter
murdamike
hey guys, has anyone put in a winters shifter in a 97-03 f150 before? im looking at one for my truck PN #327-1 just was curious if anyone has ran one or know of someone running one and their stock trans 4R70W
We ran one on our 5.4 but it had a 4r100. Not exactly the same but you should be fine. If u have overdrive u can wire it to a switch from what I remember based on the research I did 15 years ago.
little different part number but they say they work for the stock trans so im stoked!
i was just thinking that too Ryan i know when i was driving it the switch that was on top of the shifter broke but i spliced into it and extended it and drilled a hole in the cover the surrounds the steering column and mounted it there for the time being until i got it fixed correctly i would imagine i will do the same for the overdrive button
I would get the -3 Transgo kit so you can really control it and manually shift.
