Wheel help
RideRedBrotha
Starting my first prerunner build and just trying to figure everything out. So sorry if this is a dumb question. The truck is a 2003 Ford Ranger. Im trying to find a nice set of wheels to fit it (kmc, raceline, method) but am very limited on options. The stock pattern is 5x4.5 I believe. What can I do without needing to run some cheap pos wheel adapters? Any upgrades I could do that would be stronger and also open up some more options?
Not trying to sound like a smartass, but to answer your 1st question: Buy wheels with the correct bolt pattern? A 2 minute search on Methods site says they have 11 different options in many colors for an 03 ranger.
The 2nd part: Stronger than what? The stock wheels? The aftermarket ones you mentioned? What exactly are you doing to your truck that makes you think you need extra-strong wheels?
Dont overthink it. Just get some wheels that you like, make sure you get lugnuts thatll work with em, and have fun.
Call our friends at Poly Performance they will set you straight.
Use Code BADLINES10 for 10% off
And yes what @desert_steve said
