Giant Geoff
I do not. The spring cost will be too much.You guys make 4.0" internal bypass coilover?
I've been tuning up my 3.0" IBP to be very progressive to where you don't need a hydro bump. I have a 6" needle with a tight fit that has very little bleed plus I close off the last bleed hole in the piston to almost hydro lock the shock. You can push you truck very hard without bottoming out!
