RSS Shop Bronco
RothShocks
My 89 Bronco, it’s a pretty simple build that’s been on jackstands for the last year because the government job didn’t pay well and it’s hot out here in AZ. Currently building a single swing for it when I get some free time .Pretty much everything is used on it.
Front suspension
-Fox 2.5x12
-Locked 2.5x4 (shortened)
-Giant Drop Bracket and Radius arms
-Single swing
- between 15-19~ travel
Rear Suspension
-Gen 2 take offs valved for a bronco
-Giant under the bed shock mount
-National Race pack
-Stock F250 shackle and Camburg hangers
Completely Stock drive-terrain
Currently getting it ready for next season finishing up the single swing, Uniballs for the beams, New radius arm mounts, Converting old Hella Rally’s to Led , 5/8 studs all around, new brakes, maybe 37s if I can find some 5 x 5.5 beadlocks out here but doubt it.
Random Picture from Installing the new to me solo engine cage
My 89 Bronco, it’s a pretty simple build..........
ive got some 5x5.5 KMC beadlocks ill sell ya! 17k! comes with a whole truck and its LOCAL PICKUP FOR YOU!!!!!!!!!!!
I'll even cut ya a deal since i have a thing for 89' Broncos............ 16k even!
No pictures yet but got tired of looking at it on jackstands ended up buying new stock steering to get back in the desert. Put it 85% back together on Sunday just needs fluids, battery, final torque, and some trimming on bolts.
Very cool truck!
I would cancel the steering because the drop brackets take scrub out of the suspension and reduces the harm and stress on the stock steering. If you bend them, it’s most likely because of a nasty hit that you will avoid next time. This way you’ll get it complete enough to use.
I'm going to hang on to the swinger and tabs I got until I go wider, the next plan is just drive it till I start breaking my old national leaf pack and then put on a set of 48 links and 3.0s I have laying around with the 8.8 until that breaks in half and then go wide with a 9 in and make the front match. Just going to get it driving again and do the little projects like big K&N ump style filter, Convert the HIDS to LED, build a rear bumper, clean up the rear rack, move the battery to the back etc nothing to crazy hopefully that will take it down for another year in a half
Was rushing last Sunday, assembled the hub and noticed the axle wasn't fully Seated so I got more practice at that and did it again. Got stock steering on in 5 mins. Went to bleed the brakes and did the passenger side then went to the drivers and noticed the caliper wasn’t there and it was resting on the frame. Then ran out of brake fluid. Hopefully I’ll find time in the next few weeks to do final prep and fluids and get it back on the road.
Very cool! Push the piston in on the driver side and you may have enough fluid to where it fills it back up to make it work.
Looks like you need a drop pitmen arm to help the steering.
Bronco mainly holds customer shocks during assembly and disassembly, currently debating to keep it and build it with the links or pass it on for a new more finished toy since I don’t really have time to build it the way I want.
Bronco is going up for sale to expand the business. decided to post it for sale for 13,500 in a few spots ill probably make one on here as well but went out and took some decent photos of it. hardest part for me getting rid of it is i want it to go to a good home where i know someone's going to build it right.
So no good offers on the bronco for the last three months so I did the only rational thing I could think of which was smoke a big bowl and order all the SendCutSend files for linking the rear.
In the beginning of May I’ll be getting upper, lower link mounts welded up and a universal DIY offroad truss for the 8.8 and I’ll be starting the cage after hours. Going to try and keep it as simple as possible and I’m going to run a 2.5x12 (my front shock ) in the rear with a 3.0x14 bypass if I can find a okay set for cheap .Then Cut off the solo cage and make my 3.0x14 kusters fit up front.
Edit : Leafs are for trees
hell yeah man!
all I'll say is............ I hope you do it and finish it. haha. linking THIS thing is A HUUUUUUUUUUUUUGGGGEEEEEEEEE project. hah
