More build help
Jonasg05
Recently bought a set of plated 4 in bent beams from a garage sale does anyone know what size shocks to run already bought the coils just not sure on shock lengths and size or what length to strap it at
can you give us more details on the vehicle?
Typically 12-14" coilovers will work depending on where you mount the shock mounts on the beams and how you are mounting them in the engine cage.
They are stock beams it’s currently my daily so I’d prefer to not get an engine cage this season was planning on doing a mild build for this year then swapping to a giant front end next summer after I buy another truck would prefer to go the coil spring route unless it’s totally not worth it
They are just bent not extended
What are you planning on doing about radius arms? Stock coil buckets? Do the radius arms (if you have them) already have lower shock mounts?
i know with camburgs old coilbucket system they ran an 8" 2.5 sway a way shock. but that would still require custom shock mounts... If you are utilizing the stock coilbucket and shock location.... i have no idea.
