might build a street strip car
turbomonty
southern oregon
i got my mountain 4x4 truck. i have my dunes desert rig. now i am thinking i need some street semi fast thingy!
the foundation will be my spare 3.0l duratec V6 and another 6hp26 fully semi automatic trans.
at first i was thinking RWD festiva but kinda wanted some curves.
found some old iron cars for kinda affordable on facebook
had chatbot dream up some image of how fun this can look.
~ 1960 Renault dauphine for 500$
chatbots a total beer buddy talking it all up. seems semi believable to me!
Here’s a breakdown of your Renault Dauphine build with your turbo Duratec V6 + 6HP26 trans setup, focusing on:
  • Component weights
  • Estimated total weight
  • Drag performance estimate
🧱 Component Weight Estimates
ComponentWeight (approx.)
Stock Renault Dauphine body~1,433 lbs
Remove stock drivetrain (engine + trans)–200 lbs
Duratec 3.0L V6 (iron block)~350 lbs
Turbo setup + plumbing~50 lbs
ZF 6HP26 6-speed auto~260 lbs
Driveshaft + diff + axles~120 lbs
Fuel cell + lines + pump~50 lbs
Cage + mounts + chassis work~150–200 lbs
Radiator + fans, cooling setup~40 lbs
Misc. wiring, ECU, battery~40–60 lbs
⚖️ Total Curb Weight Estimate
  • Original car: ~1,430 lbs
  • Modified (net): ~2,200–2,300 lbs
    Depends on cage size and how stripped or finished it is
🏁 Modest Drag Performance Estimate
Assuming:
  • ~450 hp
  • Decent drag radials (e.g. 275/60R15)
  • Rear-wheel drive
  • Moderate launch control (no trans brake)
Performance SpecEstimate
1/4 mile ET10.2 – 10.7 sec
Trap speed132 – 138 mph
60-ft time~1.6 – 1.8 sec
With less aggressive boost (say ~350 hp), expect low-11s at ~125 mph.
📌 Summary​
  • Power-to-weight: ~4.9–5.2 lb/hp = supercar fast
  • Body will need reinforcement and aero tuning for stability above 120
  • Could hit 9s with higher boost and weight reduction
Want a visual spec sheet or mockup layout of the drivetrain in the Dauphine?
That Audi is badass. I'd love to get one like that and swap in a turbo rwd drivetrain from something like an s2000 or bmw
What's that big window red thing behind this audi. Looks like a 55-59 Chevy cab from behind
Copy. I know nothing about pre 67 ford trucks. Not a fan of old ford trucks or cars really till you get 1941 or older.
Oh man, I love oddball cars. My first real project was a 59 rambler American coupe with a 383 stroker smallblock, 400 trans and a 9”
Built a janky ass front end using mustangII/pinto parts from the junkyard. Car was a total death trap. Can’t believe my dad let me drive that thing.
Those renderings are bad ass. Way cooler than another chevelle, nova, etc.
i want it to be in-between a gen 1 falcon and original size. i am 6'2"
i am thinking dual stacked led headlights
1000% prowl over them
small fins in the back
need to source modern doors that are square on the front and back and then get a windshield to match them. it will glue in
hood can be about anything trimmed to taper between the fenders
narrower grille
fender mirrors
power train
3.0l duratec with cheap 3076 turbo = easy 450hp
easy street is another 6hp26 auto but have not axed out the desire to get a nissan cd009 6 speed manual!
